where do ur vlave cover filters go?
Old Sep 16, 2005 | 05:32 PM
snakethis69's Avatar
i got two and put them on either end of where that tube goes into the TB and into the valve cover is this correct?
Old Sep 16, 2005 | 06:01 PM
Jazsun's Avatar
Re: where do ur vlave cover filters go?
wtf? are you talking abou this vent things for valve cover that do ****?
Old Sep 16, 2005 | 06:21 PM
sscott's Avatar
They go where the oil filler tube is on the passenger side of the vehicle, at least that's where mine is.
Old Sep 16, 2005 | 06:47 PM
hum,. i didnt put it there. i will post a pic http://68.58.166.143:89/pictures/temp/
Old Sep 16, 2005 | 07:31 PM
shady_ws6's Avatar
I thought they went where the filler tube is.
Old Sep 16, 2005 | 07:47 PM
Why are you putting these on?
Old Sep 16, 2005 | 08:05 PM
ss97dml's Avatar
why would you put a breather on a t.b.
Old Sep 16, 2005 | 08:18 PM
SS RRR's Avatar
I sure hope is isn't from the old yenta tale of being a culprit of the intake leak. That rumor needs to die and rot away!
Old Sep 16, 2005 | 09:38 PM
no i put them on cause i got them for free and my tube that goes there is cracked and is taped with pressure tape so i figured it cant hurt anything.
Old Sep 16, 2005 | 10:15 PM
Originally Posted by snakethis69
...so i figured it cant hurt anything.
That's not totally true. If you don't also eliminate the vacuum side of the PCV system, you are causing a small vacuum leak. The computer will eventually adjust the long term fuel trims to compensate, but putting on the breather really just causes a "false" estimation of what air is coming into the engine.
It also makes crankcase evacuation less efficient than the closed PCV system. The PCV system removes harmful gases from your crankcase. So, again, you aren't doing yourself any favors.
I'll bet you could have bought a new hose from the TB to the valve cover for less than you paid for those breathers.
Old Sep 16, 2005 | 10:22 PM
breathers = free. i mean my hose works. nothing wrong i fixed the leak. i guess i'll just put it back on then. what are those things for then?
Old Sep 16, 2005 | 10:45 PM
Lol, yeah, I forgot the free part. Breathers are more for non-street or blower applications or cars that don't have closed PCV systems. For our "normal" cars, it's better to keep the closed system, IMHO.
Some people stick them on their cars because they see engines at the track with them on there or equate any hose on the engine as a power robbing emission device.
Old Sep 17, 2005 | 09:25 AM
ah ok. well i will just put the hose back then
HectorM52
Jul 30, 2017 11:46 AM
Apr 3, 2015 10:54 AM
David Dorris
Jan 17, 2015 08:10 PM
Jazsun
Dec 29, 2014 12:14 PM
