where did you put your MSD box
Re: where did you put your MSD box
go through my pics and you can see it. I moved my fuse box underneath its own bracket and made a metal plate. Then mounted the plate to the fuse box bracket and bolted the box to that. worked out pretty good i must say.
http://gallery8926.fotopic.net/show_...n.php?id=23663
Where I had mine, it's coming out this weekend, won't need it with the LTCC on my new build in the shop. It cleared everything fine, I used some small 1/8" washers to allow a flush mount on the fender where it curves, clean fit.
Here is a shot of where I put mine. We took a cutoff wheel and recessed a box in the fender well and and welded in metal where there was openings. Bondoed it all back smooth and mounted my dig6 down. The first pic looks runn i was doing some winter cleaning.
But i soon cleaned her up
same here... i used the 3 spacers they provided, and 1 straight screw right down...
http://img507.imageshack.us/img507/5...mounted0pv.jpg
Since I installed a "weeee", the factory routing of intake duct work moved, and that left a huge gaping hole.. So I built a bracket out of aluminium that hangs on the factory filter box tabs. It's also home to the meth injection soleniod and some leds. If I ever add an intercooler it will have to go, but looks kinda oem for now..
sorry to be an image hog.
Jan 13, 2015 09:52 PM
