Where to check for major power loss- new motor, trans, rear
Old Jul 11, 2005 | 08:08 PM
  #16
turbo_Z's Avatar
Re: Where to check for major power loss- new motor, trans, rear
Originally Posted by lookingformore
To be honest i don't know the specs on the springs but the came with the fully assembled AFR heads from AFR. I didn't install the cam. shop did. And at the time of re-build, i was told the compression was about 10.4/1.....isn't that around stock compression....is that the compression i should have with this set up....
Id call AFR to ask them what springs they put on those heads. The cc305 isnt a very large cam so it wont require anything too crazy but the LT4 springs if thats what was used MAY float the valves.
What you are referring to is static compression ratio. You need to get a compression test that checks to see if there are any cylinders that dont hold a compression be it leaking thru the rings or valves in the head.
Old Jul 12, 2005 | 04:36 PM
  #17
mkent's Avatar
any find on the power yet? I've had the same problem for over a year now. I have not readjusted my valves because the car runs too smooth and I am on the stock fuel pump, but my pressure looked fine the last time i checked it.
ulakovic22,
did your car run fine when your valves were too tight? I don't want to go through the trouble of readjusting them if it's not the problem, but with the mods listed in my sig, I should have alot more than 298rwhp, 307rwtq!!!
Old Jul 12, 2005 | 06:28 PM
  #18
lookingformore's Avatar
I know i have to get a leak down test........is that something i could do or find a shop to do it?
Old Jul 12, 2005 | 07:03 PM
  #19
Also wanted to note that on occasion if i blimp the gas or on a hill i will get a backfire.....any ideas.....is this something competely different?
Old Jul 13, 2005 | 08:13 PM
  #20
Z95m6's Avatar
If you are getting a back fire, its a timing issue. I would look towards, crossed plug wires, opti, or the cam being installed wrong.
Old Jul 14, 2005 | 05:12 PM
  #21
The cam seems to be coming up in all my posts.......only way to know for sure is to pull it and install again or install new one...which is what i would do if it came to that....Plus what do you guys think if the Taylor over the valve cover wires....is that a good place..i'm on my third set (shop installed) by running them below the headers.....maybe if i get in there and do it myself right?......But still deciding on what type to install......would you believe after all this work..going through MSD & Talyor wires they put on mow factory 7mm wires.....
Also even though Opti is new can it go bad rigthh away....or be installed improperly.....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
