Where can I pull switched 12v power under the hood????
Old Jun 24, 2003 | 01:14 AM
96 WS6's Avatar
This is the last thing I have to do before my monster tach is operational. Thanks.
Old Jun 24, 2003 | 03:49 AM
sideways_Into_3rd's Avatar
if its for turn on signal power .. use ur ign fuse
if its to draw any power . run a relay
Old Jun 24, 2003 | 02:35 PM
96 WS6's Avatar
So what I tap into the pinkish wire under the fuse box??? TTT
Old Jun 24, 2003 | 03:22 PM
96 WS6's Avatar
Come on PPL I don't want to mess with some wire I should not mess with. TTT.
Old Jun 24, 2003 | 03:51 PM
kirschman's Avatar
I'm not sure if it the same on the pontiac, but, I used the fuse box inside the car (open drivers door, on side of dash) and the is a few extra lugs u can use a spade terminal on. I think there is some that are switched and some that are batt. I hooked my auto-meter quick lite up there with no probs at all. I used the ign. terminal, lite comes on when u turn on the key for a sec. , kinda cool looking
Old Jun 24, 2003 | 04:04 PM
The tach is inside the car, right? Why go under the hood when there is power at the fuse panel in the dash?
Old Jun 24, 2003 | 04:48 PM
96 WS6's Avatar
Well I used speaker wire to wire it and since there are two wires together I just ran them both into the engine bay not really thinking that it would be inside the cabin (somebody in another post told me to grab anything from the underhood fuse box.
Is there anything I can tap into or do I have to take the whole wire back into the car and then separate it? I would rather just tap under the hood the wire is sitting there, stripped, waiting for a connection.
Old Jun 24, 2003 | 04:55 PM
Ok, well that changes things a little.
I would tap off the IGNITION (fuse 11), since that is the one that powers the coil and coil module (would seem to be right for tach power ). It's pink. Most or all of the pink wires are only hot with the key ON.
Old Jun 24, 2003 | 05:02 PM
96 WS6's Avatar
Thanks shoebox!!!! That's exactly the one I was going to tap anyway =) So I have the fuse box off and I have separated the pink wire going into the ignition fuse, so I can just tap it right there under the fuse box?
It kind of confuses me that there is only one wire going into the fuse. Shouldn't there be one going in and one going out? I know I'm missing something stupid.
Old Jun 24, 2003 | 05:16 PM
I would have to look, but there may be a bus where the fuse gets power, therefore you might not see a wire going directly to it. It has to get power from somehwere, though.
Old Jun 24, 2003 | 05:25 PM
96 WS6's Avatar
Yea I figured =) So just tap into the pink one and it's done then??? I'm going to do it today after class.
Old Jun 24, 2003 | 06:14 PM
The pink should do it. Check it with a meter beforehand if you want to be certain.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
XtremeLt1
Sep 13, 2002 08:50 PM
Omega9
Aug 2, 2002 12:33 AM
