Where can I get some ARP Main Bolts that work with windage tray??
Old Apr 9, 2006 | 02:25 PM
Mike96z's Avatar
I am building my 388 ci LT1 and I am trying to get some main bolts that will work with my windage tray or oil baffle, I am needing to keep the baffle on my car so if anyone knows let me know because I have checked summit. THanks
Old Apr 9, 2006 | 02:28 PM
FastZinTennessee's Avatar
Re: Where can I get some ARP Main Bolts that work with windage tray??
I went through this situation when building my motor. I think we tried swapping to some 400 small block style main studs with the windage tray extensions already on the studs. Don't quote me on this because it's been a while.
I ended up not liking how it all fit together and just bought a Canton 242t pan with the baffling and scraper already in it.
Old Apr 9, 2006 | 08:36 PM
Mike96z's Avatar
Do you think I could get away with using the stock crank bolts with my 388?
Old Apr 9, 2006 | 08:37 PM
Mike96z's Avatar
Also I don't even think that the crank will clear this baffle, It may hit it anyways so I may just have to get a regular set of the ARP bolts, because the stock crank it really clost to the baffle too.
Old Apr 9, 2006 | 10:49 PM
Mkos1980's Avatar
Doesnt Milodon make a set? Part Number MIL -81150?
Old Apr 10, 2006 | 09:15 AM
roughneck427's Avatar
Im stock stroke and i had like other members said use a few studs from a 400 because the windage tray smaller section is longer.I had this problem and did a search on it an saw when i ran into this problem guys with stroker motor couldnt use the stock tray because the rods hit it.Might check into it
Old Apr 10, 2006 | 09:18 AM
Are you talking about main bolts? I wouldn't recommend it. I had enough problems with the stock windage tray with a stock stroke crank and Eagle H-beams that I ditched the setup. If you want to get the pan that I was talking about above, you can just use normal ARP main studs without windage tray provisions.
Old Apr 10, 2006 | 09:43 AM
GetaZforgetGT's Avatar
yep...that's what I used to mount a milodon double diamond windage tray.
They are ARP bolts as far as I can tell. Nuts all have ARP stamped on them and it is rated to the same tensile strength as the ARP main studs. Torgue to 65 foot pounds with oil.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
adam85
Parts Wanted
Jan 1, 2015 02:24 PM
ddr698
Dec 31, 2014 09:16 AM
Catmaigne
Dec 25, 2014 12:16 PM
