Where can i get an Alternator relocation bracket?
Old Oct 30, 2006 | 11:36 AM
Mikes 1994 z28's Avatar
And im not talking about the ones on ebay, thunder racing or SpeedSpecialty. I want to retain my Power steering.
Old Oct 30, 2006 | 01:53 PM
Bawls's Avatar
Don't exist due to how our belt is routed.
Old Oct 30, 2006 | 01:58 PM
MeanGreen97Z's Avatar
Actually there is one to retain power steering but you lose A/C. Not positive where I saw it. Wish I had a better memory! LOL
Old Oct 30, 2006 | 02:00 PM
Bawls's Avatar
You talking about the one that adds the idler pulley in between where the alternator mounts, and you mount the alternator where the a/c mounted?
Old Oct 30, 2006 | 02:07 PM
Ya thats the one.
Old Oct 30, 2006 | 02:23 PM
Eric@Victory Racing's Avatar
Relocation Kit
Old Oct 30, 2006 | 02:29 PM
95LT1conv's Avatar
thats a nice kit. bet it makes getting at the # 2 plug a little easier too.
Old Oct 31, 2006 | 11:08 AM
Originally Posted by Eric@Victory Racing
Ive seen this one before. Not sure why they didn't just get rid of the alternator bracket as well as make the new mount adjustable to eliminate the tensioner pulley. $200.00 is a lot though. If I dont find anything cheaper, im going to make my own. Maybe Ill start manufacturing one. It would be nice to be able to throw any center bolt valve cover on our engine and it would make plug changes and inspecting your valve train A LOT easier. Not to mention handling would be slightly improved with the alternator mounted lower.
Old Oct 31, 2006 | 03:22 PM
93black-ta's Avatar
you could make your own if you dont mind losing your A/C. it also only costs about $40.
Old Dec 5, 2006 | 02:53 PM
RacerTim's Avatar
Can you elaborate on that 93black-ta?
edit: nm, found your post
Old Dec 5, 2006 | 06:25 PM
93black-ta's Avatar
take a look through these http://rides.webshots.com/album/373661912YZXxkj
it pretty straightforward to do, if you look through the pictures you can basically see everything that has to be done.
1. notch the acc. bracket for the alt to fit snug where the A/C compressor was.
2. fabricate a new mounting bracket for the top bolt hole of the alt. to mount to the PS bolt. I used a piece of 3/8 or so steel from home depot. the bottom alt bolt hole can be mounted through an existing hole in the acc. bracket.
3. fabricate a mount for the pulley that will go up top where the alt. was.
i used my A/C delete pulley with some bushings cut accordingly to get the placement of the pulley to line up with the rest of the acc. pulleys.
4. check/notch the alt accordingly for the PS line to go by. you may have to bend the line a bit.
hope this helps
Old Dec 8, 2006 | 12:29 AM
TransAm396's Avatar
i know this is kind of old..but cant you get away with putting the alternator downthere and not using that extra pulley?
Old Dec 8, 2006 | 12:40 AM
Daniel6718's Avatar
not without relocatin the ps pump somehow
btw crank spins clockwise
tensioner doesnt matter
alt, CW?
ps pump CCW?
what happens if you spin it the wrong way, the inlet becomes the high pressure and the outlet line becomes the low pressure?
or am i thinking crazy?
Old Dec 8, 2006 | 03:36 AM
blahster's Avatar
93black-ta....
how hard is it to change the plug wires with the alternator right there? looks like it might be more difficult...i dunno.
where did you get that pulley for where the alt used to be? i was thinking about making my own bracket to move the alt down to the driver side....
Old Dec 8, 2006 | 11:30 AM
526 SS 96's Avatar
I have that same kit. It's a little expensive for what it is, but it works. I had to grind away some of the bracket so I could fit the plug wires throught it. The ALT is very close to the opti, and the wires have a hard time making the turn. The best way to keep the wires from getting wasted by the belt is to route it like I did. You will notice in the pics, they don't have the wires installed. I will try to dig up some pics of my set up if you need it.
