Where to buy EGR blockoff plate?
Old Jul 24, 2003 | 09:22 PM
GrdLockV6's Avatar
Can't seem to find one, can someone point it out for me?
Old Jul 24, 2003 | 09:25 PM
Camaro_SS/R's Avatar
http://www.mycamaroz28.homestead.com/
I got mine from Steve, works great. If you want, you can make it yourself.
Old Jul 24, 2003 | 11:19 PM
ChuckZ28's Avatar
I just took one of the metal spark plug boot covers. flattened it with a hammer. cut it down with a hacksaw and drilled the 2 holes in it. only took about a half hour. Nobody will see it anyway being in the back of the intake manifold
Old Jul 26, 2003 | 10:12 AM
GrdLockV6's Avatar
How bout this... instead of going through the trouble of taking off the EGR pipe, which looks to be a PITA since it's way behind the manifold, I just took a bolt with a decent sized head, and stuck it into the end of the EGR pipe that connected to my header, put some gasket sealer around it, and a small clamp. Looks to be working just fine, and it only took a few minutes Ghetto? Yes indeed. Simple? Yup!
Old Jul 29, 2003 | 12:18 AM
QUICK305's Avatar
Go to the dealer and order an EGR block off plate for a 1996 6-speed (LT4) Corvette. It's around $7. The second one can be made fairly easily.
Or just buy from the guy above.
Old Jul 29, 2003 | 12:45 AM
CamaroBoy96Z28's Avatar
You could even make the plates out of a pop can. Some guys here have done that. I just went and bought mine from Steve too. Camaro_SS/R already posted the link.
Old Jul 29, 2003 | 06:35 AM
Smoke T/A's Avatar
Ditto Steve is a stand up guy and his plates are great.
I would not use the soda can because of the thickness. We used one on a car and a week later it blew a hole right through the can. HTH
Old Jul 29, 2003 | 10:14 AM
Hyperspeed97z28's Avatar
I simply left the egr valve on there with a cap over the vacum port, as for the egr pipe, i hack sawed the pipe to almost the end and filled it inside out with epoxy and let it cure 24hrs, so far so good!
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
heavenly_six
Dec 10, 2014 12:23 AM
