When I hit the brake gauges go wacko
Old May 30, 2003 | 03:42 AM
unTAmedLS1's Avatar
Any accesory Load causes gauges to jump
Ok here is whats happening. I'm driving along and I hit the brake pedal the slightest bit the check gauges light comes on and all my gauges and pretty much anything that is powered like stereo and headlights dim and the radar detector will restart. But if I hold on the brake then it only does it at first and thengoes back to normal like nothing happened. It seems like a short to me but it does with turning the headlights on too. Also it only happens if Im going over ten miles an hour and it was an intermittent problem, but now it does it alot more Thanks for the help in advance.
Old May 30, 2003 | 03:16 PM
unTAmedLS1's Avatar
TTT
Old May 30, 2003 | 03:35 PM
rocmemphis's Avatar
Sounds like a ground problem. Might want to check all your brake bulbs and sockets and well as any exposed wiring anywhere to see if they are cut or chaffed.
Old May 30, 2003 | 04:36 PM
Check battery and ground connections, alternator output and state of charge on the battery.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattstrike
Mar 11, 2015 07:33 PM
armedtrigger
Feb 24, 2015 08:30 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
