When to change the oil....
I've heard many say its "how" long its in the car not how many miles are on it. I've also heard that after a certain period of time oil tends to build up an acid and that is why it is better to change it every three months even if you've only put 1000 miles on it...any of that true? The reason I asked is I switched to synthetic oil about 3.5 months ago and now I'm at 3200 miles and I before I never went past 3k...everyone swears I can go 5k easy and a couple people are saying 7-10k...I will NOT go over 5k but if that whole bit about acid building up is true then I want to change it this week and not wait...let me know either way what you guys/gals would suggest.
Originally posted by Patman
You can safely go up to a year on synthetic oil. Some go even longer and their oil analysis results still look ok (I wouldn't go much past 18 months though, that would be really pushing it)
Originally posted by IrocManiac
So going to 5k (which would put me somewhere in the 6 month range) wouldn't be a problem?
you mentioned that you switched to synthetic just 3.5 mos ago, based on that i would go ahead and change the oil now since it is probably pretty dirty.... when i first switched to synthetic when i got the car, i changed after 1,000 miles because the weight of the oil, etc was different and really seemed to darken quickly. Now, 3,000 miles when i change it oil looks relatively new...
Originally posted by S.J.S.
Me..personally, synthetic or not I'm gonna changed that stuff every 3k. I've seen what happens to a motor (my own ) when you slack on oil changes.
96SilverRam
Nov 20, 2016 11:19 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
