When the A/C is ON, the car heats up a bit
Old May 2, 2003 | 09:47 AM
Highlander's Avatar
I am having a bit of problems with my A/C...
Whenever I turned it on it will start to heat up past the 1/2 mark and when its off it wont pass just a bit below the 1/4 mark...
I had the system without refrigerant for some time since I installed a cam and all that stuff... I then proceded to add refrigerant and the car cooled great and didn't heat up that much and as soon as you moved a bit it went down the 1/4 mark again...
Now.. The car heats up and it doesn't cool correctly.. I am in the process of measuring the PSI with the gauges today... but.. Anyone have any thoughts???
Old May 2, 2003 | 09:58 AM
Depending on whether you have a 2 or 3 relay fan system, one or both of your fans should come on when the a/c is on. Check to see if that is happening. Fan relays are in the underhood electrical center.
Old May 2, 2003 | 09:59 AM
Highlander's Avatar
Both fans turn on fine...
MadMav
Feb 6, 2015 11:02 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
