wheels
will 1998 camaro stock 16in. 5-spoke wheels fit on my 1994 z28? are they the same size? and also, are the front and rear wheels/tires on all camaros the same size? or are the rear tires larger/wider? in your opinion, how will it look? thanks.
They should, I don't think GM changed the bolt pattern, Why not upgrade to bigger and wider though, like maybe 17 x 8 or 9, or if you really wanna go big in the rear put 11" or if you want to do some custom work to your back end, I've heard of a camaro or firebird around here with 13" rear wheels, but you have to modify your wheel wells.
I put 00'z28 wheels on my z. I only found one problem. For some reason they want fit all the way around(rotating them) there was a post on here once about it saying you have to sand down the backs just a little so they will fit all the way around. They apparently are right because I tried to put the fronts on the back and they would bolt in tight they wouldn't catch they would slip. I have no clue though. Hope this helps
30th Anniv Z28
Aug 1, 2015 10:39 AM
jasonduaine
Jun 4, 2015 09:29 AM
