whats wrong w/ this setup
Old Mar 2, 2004 | 11:55 PM
NewbieWar's Avatar
ok i looked at this lt1/lt4 parts combo
Specs:
Block: Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed. 4-bolt main caps.
Crank: Eagle Nodular-Iron
Rods: Eagle Forged 5140 Steel SIR, 6" Length, Floating Pin
Pistons: SRP Forged
Rings: Speed-Pro Plasma-Moly
Bearings: Clevite Main and Rod Bearings
Core Plugs: Brass Pioneer Core Plugs
Main Studs: ARP Main Studs
Lifters: Comp Cams Hydraulic Roller
Pushrods: Comp Cams High-Energy
Valve Springs: AFR Performance
Rocker Arms: Comp Cams Aluminum Full-Roller
Timing Set: Lunati Double Roller
Timing Cover: New Factory
Oil Delivery: Melling High Volume Pump, Pickup Tube and HD Drive
Oil Pan: New Factory 6-Quart
Gasket Set: Fel-Pro Performance
Head Bolts: ARP
Crank Hub: Factory to match Vehicle Year
Cam:
Manufacturer:
Comp Cams
Type:
Hydraulic Roller
Operating Range:
1800 - 5800 rpm
Idle Quality:
Fair
Duration:
Intake: 226° @ .050"
Exhaust: 226° @ .050"
Lift:
Intake: .520"
Exhaust: .520"
Lobe Seperation:
112°
Heads:
Type:
AFR 195cc LT4 CNC Ported Aluminum
Combustion Chamber:
64cc
Intake Runner:
195cc
Intake Valves:
Stainless Steel 2.02"
Exhaust Valves:
Stainless Steel 1.60"
this engine kit is rated for 480 horses (probably flywheel) and 512 ft/lbs
genearlly on a poorly designed engine is the horsies less then the torque am i correct? what are the flaws in this? what could be improved on this setup?
Old Mar 3, 2004 | 08:52 AM
meengreen 94z's Avatar
Not necessarily. The motor is a 383 which provides more tq for one. The cam profile probably has something else to do with it. And for 480bhp its probably making around 420rwhp. Not horrible for AFR 195's but not amazing.
.If you look at the tq curve its making over 450tq from 2200rpm and over 500tq past 5000rpm. That looks to be an great flat curve to me.
Old Mar 3, 2004 | 09:01 AM
NewbieWar's Avatar
it seems like it falls on its face tho, that torque curve dies away pretty quickly
Old Mar 3, 2004 | 09:07 AM
If Im reading that graph correctly its making over 400 tq past 6k. A stock LT1's tq falls off past 4500rpm. That tq curve looks great to me. Its still making hp past 6k as well. Id rather make good low to mid range power than have some amazing high rpm number.
Old Mar 3, 2004 | 09:14 AM
OldSStroker's Avatar
Re: whats wrong w/ this setup
When peak hp figures are higher than peak torque figures, the engine is probably peaking power above 6000. A typical case might be peak torque at 5000 and peak power at 6500. In that case you might see your numbers reversed: 480 torque and 512 hp.
This case is the reverse, so hp peak is probably around 56-5800. That makes the fw numbers sound a little high to me. A 383 is only about 8% bigger than a 355. I think 475 lb-ft for a 355 with similar specs might be high.
FWIW, those "dyno" curves don't look realistic to me. Check the 450 lb-ft of torque below 2500. Hmmmm.
Just my $.02.
surreybrad
Aug 10, 2015 09:34 AM
Z28-50
Aug 7, 2015 01:22 AM
bunker
Aug 1, 2015 10:10 PM
detroitmuscle
Jul 31, 2015 04:21 AM
realistyc
Jul 28, 2015 07:32 PM
