Whats wrong: timing or bent valves?
Old Nov 23, 2004 | 08:52 PM
SkillZ25's Avatar
Exclamation Whats wrong: timing or bent valves?
Recently my water pump was going out so I decided to replace/upgrade it. After I installed my new CSI electric WP I took it on a test drive and was driving it normal when all of the sudden it tripped out and it seemed like it went into N (so it revved up). After it went up to like 5K so I let off the gas and either I turned off the ign. or it died when the rpm's went down(I really dont remember).
Anyways it was a no start from there so I figured out my timing chain was broken.(and later found out some teeth on the crank and cam gears were broken off).
I fixed all of that and put it back together....still a no start...no fire from the opti....so I got a Delteq.... Intsalled great....Starts now!....but the idles at like 400 RPM and sounds like ****( sounds like its barely staying alive) .....bent valves from the timing chain break or did I install my opti wrong and the timings all messed up?
Old Nov 23, 2004 | 10:40 PM
skeevay's Avatar
Re: Whats wrong: timing or bent valves?
Do a compression test...should tell you if any valves are not seating (bent)
Old Nov 23, 2004 | 10:48 PM
SkillZ25's Avatar
Was planning on that one. I will. But is there a slim chance that I just put my opti on wrong and the optical senser is broke?
Old Nov 24, 2004 | 02:59 AM
SkillZ25's Avatar
..bump
Old Nov 24, 2004 | 06:57 AM
bradpreece95z28's Avatar
I would say that you have VERY good chance of finding a bent valve(s)
Do a compression test. There shouldnt be alot of variance between cylinders.
If there are bent valves, might wanna worry about some valve to piston contact as well.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
