Whats the purpose of this line??
Old Mar 28, 2004 | 01:47 PM
S.J.S.'s Avatar
Okay, bare with me. Its the vacuum like line that goes from the fuel lines on the driver's side of the engine valve cover area and goes under the TB and up around the TPS and connects to the filter like thing. The reason I ask is I found mine disconnected near the TPS this morning.
thanks.
Old Mar 28, 2004 | 01:55 PM
Spinner's Avatar
EVAP (Gas tank vent vacuum?)
Old Mar 28, 2004 | 02:19 PM
S.J.S.'s Avatar
so it really doesnt do nothing.... well negative anyway because it was disconnected right?
Old Mar 28, 2004 | 02:22 PM
It's an EVAP hose.
Old Mar 28, 2004 | 02:33 PM
S.J.S.'s Avatar
Hey Shoe... so does it have any negative effect if disconnected and just hanging???
Old Mar 28, 2004 | 02:35 PM
It would be a vacuum leak every time the EVAP solenoid was energized. Plus you might get a few fumes out of the hose going back to the gas tank.
Old Mar 28, 2004 | 03:10 PM
S.J.S.'s Avatar
Sorry to keep bothering you Shoe. (like always). Would it effect the performance of the car? Seemed to be runing normal.
Old Mar 28, 2004 | 03:39 PM
I guess it does not bother it too much since you did not notice. The PCM would make adjustments to compensate somewhat. It would not have been a constant leak (like I said-only when the solenoid was energized).
Boss002
Jan 20, 2016 12:17 PM
pimpen1024
Aug 19, 2015 08:36 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
