Whats the next step to upgrading air intake?
Old Feb 11, 2005 | 08:44 PM
pHEnomIC's Avatar
I got a moroso cai, hypertech airfoil, tb bypass and was wondering what i should do next on the intake side.
I plan to block off the resonator tube, maybe port the tb a little bit
Dont want to descreen or port the maf.. too risky
Can't do f/i as of now
Anything else easy to do?
I heart you can shave off a little of the stop for the tb so you can open the fins more. I know thats the case for an ls1 but is there any way to do that on an lt1 and has anyone done it with satisfactory results?
Also, does making an underbody ram air sort of thing help at getting more air to the cai or is it better just to have it in the closed box like normal?
Old Feb 11, 2005 | 09:05 PM
GreenDemon's Avatar
Re: Whats the next step to upgrading air intake?
Most LT1 tb blades open the full 90 degrees- I had a problem with mine for a while but it was the throttle cable coming loose, not the tb itself.
An underbody ram air setup probably won't give you anything.
If you're set on doing your intake completely, get a vortech or trick flow metal elbow in place of the rubber one, and get a 52/58 mm tb. That's basically all that's left. Although you could get more power from other areas of the car most likely.
rjc1629
Jan 27, 2015 10:46 AM
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
