Whats Next For My 383 Project ????
Ok this is what i have so far i got the 383 short block ordered from golen all forged, le2 setup with custom cam (lloyd) all top end components such as rr,lifters pushrods ect... i dont want to take it to shop yet to get it assembled until i have everything some input would be great thanks
Re: Whats Next For My 383 Project ????
I'd add atleast injectors onto that list. Also, you should of held off on the pushrods. You might require a different length considering the heads will be milled and the block decked probably.
You need a sig with your car's current setup so you can recieve educated responses.
I'd plan on at least 36lb injectors, and a tranny/rear-end that can take
some serious abuse.
some serious abuse.
