What's needed to make a 94+ cam work on a 93?
Old Nov 5, 2004 | 11:35 PM
toegead93's Avatar
I have a '93 z28 and just bought a new cam for 94+LT. Do I need to cut the dowel pin for it to work in my car? I think I've heard someone mention this before.
Old Nov 6, 2004 | 12:36 AM
BTM's Avatar
BTM
Re: What's needed to make a 94+ cam work on a 93?
Yeah, your distributor runs off the center gear drive instead of the offset long pin that you see, so that pin needs to be shorter to not interfere with the timing cover. I'm having the same problem in reverse - I'm trying to run a 95 Optispark on a 92 LT1 that currently has a cam with the short pin, I need the long one.
At least yours is easy - you can always make things shorter. Take the measurement of the pin off your old cam and cut the new one (carefully, straight, and smooth) to the same size.
Old Nov 6, 2004 | 10:39 AM
Fastbird93's Avatar
Your statement is kind of vague. If the cam was meant for a 94 LT1, then you don't need to do anything other than throw it in the car. If the cam was meant for a 95-97 LT1, then yes, you need to cut down the dowel pin.
The 94 LT1 had the same opti and drive setup as the 93 did, so there is no difference in the dowel length on the cam. The change happened in 95.
Old Nov 6, 2004 | 11:58 AM
toegead93's Avatar
That sounds right to me. The cam card said for 94 and up LT1 V8 350ci, thats where my question came from. The dowel is on it so I just need to cut to match the stock cam.Thanks.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
