Whats the limit of 22 lb. injectors?
Old Feb 3, 2003 | 11:54 PM
allmotorta's Avatar
I'm tossin in a cc306 w/ stock heads plus I have full bolt ons. Should i upgrade to 24#ers or will the 22's be ok for now? Also, I might toss a 125 shot on top of it in a few months.... Thanks!
Old Feb 4, 2003 | 12:10 AM
madwolf's Avatar
I'd go with some 24s, especially with the 150 shot....
Old Feb 4, 2003 | 01:20 AM
allmotorta's Avatar
Thanks for the input again madwolf Anymore opinions?
Old Feb 4, 2003 | 02:19 AM
Fear The Z's Avatar
What size injectors come with the 94 LT1?
Old Feb 4, 2003 | 05:25 AM
stihlajohndeere
Guest
Posts: n/a
Will 22# work
In the Feb 2002 edition of Chevy High Perfomance mag. they give a formula for injector sizing but you must know how much HP you expect to have. The formula is Inj FR=engine hp x 0.5 divided by 8injectors x 0.8 The 0.5 is efficiency of the engine (they say to use 50%) and the 0.8 is the duty cycle of the injector. By this equation, if we assume you have or will have 400HP then 400 x .5 is 200 divide this by 6.4(8 x .8) and the answer is 31.25 so you go to the nearest size up which is 32#. If you run with too lean of injector you will burn valves and pistons. I have seen this formula since in a lot of other publications so I feel it is correct. Good luck. Go to CHP web site to check for yourself
Old Feb 4, 2003 | 05:42 AM
stihlajohndeere
Guest
Posts: n/a
Sorry the answer to your question of how much will 22# inj support is 22 x 8 x .8 / 0.5 and the answer is 281.6 HP you are seriously under fueled. Did you relace the fuel pump and add an adjustable regulator? These 2 things are a must. With the new cam and exhaust you have to be pushing 320 HP you need to get new injectors and get to a chassis dyno. By the way 17 x 11's with 7.75 back spacing will fit in the back allowing 315/35's according to CHP Jan 2002 edition. Think about that for bite at the track. Is your car Hugger orange? if so can you give me the color number I want to us it in the spring on my car.
Old Feb 4, 2003 | 06:42 AM
IDOXLR8's Avatar
I also would recommend going with SVO 24 lb injectors. Personally I think the 22lb injectors that come in 93's are garbage.
Old Feb 4, 2003 | 07:37 AM
D Rubenstein
Guest
Posts: n/a
In 93 the LT1 was batch fired injection. You may want to consider switching to sequential FI like the 94's and up use. Pay attention to the sizing. for you 24# is too small and check pump, filter and regulator. Also get a fuel pressure gage. This is a must if you are using the giggle gas. Check with tuners using batch fired Injectors with NOS. You may need a better ECM.
Good luck
Old Feb 4, 2003 | 08:43 AM
madwolf's Avatar
Yep, 24 SVOs are a great idea. They were initially rated at 39.2 PSI (Ford pressure) so the will work as 25.xx lb/hr on our 43.5 PSI.
Old Feb 4, 2003 | 09:13 AM
Fastbird93's Avatar
How easy would it be to swap to the SFI from the Batch Fire?
Old Feb 4, 2003 | 09:25 AM
IDOXLR8's Avatar
There is no reason to convert over to SFI. I would stick with batch-fire
Old Feb 4, 2003 | 11:27 AM
Lon93Z's Avatar
Not sure about the limit of power that can/should be produced with 22's but I've dynoed 295rwhp on my 22's with the stock way rich fuel pressure.
Old Feb 4, 2003 | 11:56 AM
IDOXLR8's Avatar
You may want to look into an Adjustable Fuel Pressure Regulator. I picked up 10 rwhp and 17 rwtq with a setup similar to yours.
Old Feb 4, 2003 | 12:33 PM
allmotorta's Avatar
Heavy 17 X 11's? Naah...I'll stick to my 15 X 8's with fat Nittos....
Old Feb 4, 2003 | 12:36 PM
allmotorta's Avatar
Ditto. The only negative thing about batch fire is a slightly rougher idle. It runs just the same at WOT...
