Whats leaking? (accy bracket/belt tensioner area)
Old May 22, 2007 | 01:48 AM
dueno's Avatar
I have an accumulation of droplets of a yellowish liquid on the underside of the accessory bracket in the belt tensioner area. I'm positive its not oil, so I'm assuming that it is either power steering fluid or coolant. It seems sort of oily, but not as oily as oil lol. I'm sure there are no leaks from the radiator, coolant hoses or the waterpump. I looked up at all the accessories, but I can't see where the leak would be coming from. Aren't the heater hoses routed down there somewhere I'm not sure? Any ideas on where I should look before I start tearing things apart?
Old May 22, 2007 | 06:11 AM
SnakeOiler's Avatar
check you battery, specifically the positive post. make sure it isn't leaking
Old May 22, 2007 | 09:42 AM
Z28SORR's Avatar
Did you check the weep hole on the water pump?
If it's so small that your not adding fluid to anything you can probably let it go until it becomes obvious.
Old May 22, 2007 | 01:24 PM
dueno's Avatar
Nope, its a brand new battery, nothing leaking on it. I just installed an electric waterpump, new radiator, and new hoses, so I'm sure none of those are leaking. The weep hole is blocked off with a freeze plug and sealed with RTV.
Old May 22, 2007 | 01:30 PM
2000GTP's Avatar
I would examine the power steering pump and the hoses thoroughly for leaks. Also, look over the A/C components, sometimes if there is a leak in that system, it can leave an oily substance as well.
Old May 22, 2007 | 02:24 PM
dueno's Avatar
Yah, I'm thinking its one of those. I'm gonna get under the car today with a light and try and figure it out. I'm also thinking about wiping everything really clean, and then checking a few days later to see if I can find the source. The leak isn't too bad yet, and I haven't really noticed any of my fluid levels getting lower.
Old May 23, 2007 | 10:43 AM
Z28SORR's Avatar
Sorry, didn't see the "electric water pump".
The oil that's in your A/C compressor is a light yellow.
Old May 23, 2007 | 11:04 AM
Jazsun's Avatar
my a/c compressor leaked all its oil, its a yellow color and feels oily. now my a/c doesnt work
Old May 23, 2007 | 12:15 PM
fbodyboy's Avatar
thats a/c oil. power steering fluid is clear or brown. when a leak around the compressor happens it will leak oil. put some a/c dye into the refigerant and then check it to find the leak.
Old May 24, 2007 | 02:23 AM
dueno's Avatar
Ya, its probably my AC. I've been noticing it isnt too cold lately. I also had to move those hoses alot when I did my cam swap.
Old May 24, 2007 | 08:13 AM
Don 97 SS's Avatar
Yep, been there done that, too.
HectorM52
Jul 30, 2017 11:46 AM
Nellsw88
May 26, 2015 05:55 AM
BigWil
Mar 29, 2015 12:24 PM
skittlez87
Dec 29, 2014 03:24 PM
squarehead
Nov 21, 2014 08:02 PM
