whats the highest comp ratio you can run
Old Feb 24, 2004 | 08:41 PM
rob97ss's Avatar
what the most compression you can ran on pump gas with out running into any problems?IM lookin to get a rotating assembly from combo motors and he said with -5cc srp pistons and my lt-4 heads i would be at 11.5 comp,what do you think is that to much?
Old Feb 24, 2004 | 09:08 PM
Dave89IROC's Avatar
that would be ok if you run a cam with lots of overlap to bleed off cylinder pressure
Old Feb 24, 2004 | 10:22 PM
Ai's Avatar
Ai
With the camshafts LTx guys normally run, I wouldn't anticipate issues provided the tuning was decent. With a new shortblock altering static compression isn't too big a deal, so you could always back down to 11:1 if you really wanted to.
A search on the topic of Dynamic Compression Ratio may be of some interest to you - there have been some excellent threads on this site regarding static & dynamic compression ratios .
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
