Whats a good Injector
Old Apr 29, 2004 | 12:45 PM
md1's Avatar
md1
I just had the Opti-Spark, Wires, Spark-Plugs and Water pump repalced. ( Thanks Jason for the great Prices) The guy who did the work said I need to replace my Injectors (car has a 150,000 miles on it) He said the pump is good. He has no reason to just make this up He knows I will install these myself. What I need to know is what kind to get, I think Ford Racing ones will work and they are alot cheaper. But what kind and where to get.
Old Apr 29, 2004 | 12:47 PM
Mike383LT1's Avatar
injectors
for the price get the ford
Old Apr 29, 2004 | 01:09 PM
IDOXLR8's Avatar
I believe you are referring to the SVO injectors (made by Bosch). I would go that route before I paid for a new set of OEM injectors. If not I would look in the for sale section for some used OEM injectors.
Old Apr 29, 2004 | 07:23 PM
md1's Avatar
md1
Thanks for the reply, I order some this weekend
Old Apr 29, 2004 | 07:47 PM
Tony Danza's Avatar
and dont forget to get the computer retuned for them
Old Apr 29, 2004 | 08:20 PM
md1's Avatar
md1
Dose anyone know why accel say 26 LB for stock and 30LB for intake and exhaust. on 1994 to 1997 camaro ?
Old Apr 29, 2004 | 08:26 PM
Spinner's Avatar
24lb is 94-97 stock injector. 22lbs in 1993.
Old Apr 30, 2004 | 06:06 AM
IDOXLR8's Avatar
That is weird. Hopefully, you did not order 26 lb injectors.
Old Apr 30, 2004 | 07:06 AM
ibanez6rg's Avatar
Why not get stock replacements and save money? You have no need to get any bigger.
Old Apr 30, 2004 | 07:33 AM
IDOXLR8's Avatar
Brand new stock injectors will be more than SVO injectors. That is the reason I suggested he buy some used ones off the for sale section.
Old Apr 30, 2004 | 09:11 AM
md1's Avatar
md1
I going with the Stock size 24 LB but going with Ford SVO @ $219.00 from Summit or Jegs beats the heck out of $517.52 for Factory ones. Thanks for the help
Old Apr 30, 2004 | 09:14 AM
96capricemgr's Avatar
The SVOs and reprogramming for them is cheaper than stock replacements, the cheapest I could find stock rebuilt units was something over $40 apiece(some up to $90), whereas the SVOs are a better matched set and only $220 or so for a full set, makes the decsision real easy.
The accell think might have to do with rating them at a different pressure, that and on some other vehicles it is harder to retune the pcm so when guys do something that changes the motor they throw bigger injectors at it and let the O2s pull all the exessive fuel they are dumping in. Not to mention the aftermarket would have us believe that their injectors are a performance upgrade over functional stockers which they aren't. The only times to consider new injectors are failing stockers, stockers have become too small due to at least a LARGE cam most guys will need heads and cam before this applies, forced induction that will spike fuel pressure becuase at too high a pressure the stockers lock closed whereas the SVOs lock open and won't do so till a higher pressure.
Seems like most LT1 tuners prefer the SVOs over the Accels anyway, something about the pcm tables being a known factor for the SVOs and the Accels can be tought to dial in just right. Aslo heard some hard start complaints about the Accels.
Old Apr 30, 2004 | 09:21 AM
ibanez6rg's Avatar
I'd just grab some out of the for sale section or eBay for less than $100.
Old Apr 30, 2004 | 09:36 AM
RoMaD's Avatar
I guess I was always under the impression that the stock injectors did not have a lot of headroom. Still, for $219, I'm buying new ones soon, and I won't be buying stock sized injectors. I'll probably get 30lb. and just reprogram with LT1-Edit until I have enough mods to take advantage of them. Personally, whether they're needed or not, if you have the means to program for them, I say get the cheaper set, even if they are rated higher than stock.
I think there are way too many knee-jerk reactions to mods like this. The throttle body debate comes to mind. So what if they're bigger, just update the programming and go about your way.
Old Apr 30, 2004 | 10:03 AM
If future more serious mods are in order then absolutely step up to larger injectors now if you have to replace them no sense in buying a near stock set now just to outgrow them in a year or so. This is exactly why I tell people to think about a future cam swap before automatically buying 1.6 rockers since some cams get a little extreme on the exhaust lift with those and 1.5s are a better choice then.
I know of people making over 400hp on stock injectors, so there is room to grow before needing to replace them. When programming for the 30lbs. units you do know there is more to it than just the size rating.
