whats the disadvantage to low rearend gears?
Old Mar 9, 2003 | 11:05 PM
greg0101's Avatar
i hear that putting 411's in the rear lowers the life span of your car, is this true? What does this mean.
Old Mar 9, 2003 | 11:09 PM
Z95m6's Avatar
They lower the life span of your car because the drivetrain spins more/faster than it use to. Also your gas mileage will go down too.
Old Mar 9, 2003 | 11:16 PM
dust6928's Avatar
noise mostly. if the rear is not setup perfect it whines loudly. gas mileage will suffer at first but it will be because of you, not the gear except at prolonged runs above 85 or so on the highway. another disadvantage is you wont always be able to use your gear because then your friends without a 4.10 wont be able to stay up.
Old Mar 10, 2003 | 01:05 AM
slashz28's Avatar
traction
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
29
Mar 25, 2015 04:21 PM
ddr698
Jan 9, 2015 10:05 AM
