whats the differencs in the walbro 255 and racetronix walbro with harness??
Old Oct 19, 2005 | 08:30 PM
red96z's Avatar
one is a walbro 255 pump for 120 bucks while the other is a racetronix walbro 250 and contains a harness can someone please explain the differences in the two and is the harness worth the extra money?? thanks a bunch cause i need to order tomorrow!
Old Oct 19, 2005 | 08:44 PM
hvyss's Avatar
Re: whats the differencs in the walbro 255 and racetronix walbro with harness??
I just installed the Racetronix 255l kit in my Impala SS this past weekend. It is well worth the money. The harness keeps a constant voltage to the pump at all times. Even at WOT there is no voltage drop at the pump to keep a constant flow to the injectors. My car was easy due the tank is in the back and comes down by taking out two bolts to drop the tank straps. Yours is different. You will either have to drop the rear end and drop the tank or cut a hole in the hatch floor to get to the tank cover for the pump. either way not fun. Good luck.
HVY SS
Old Oct 20, 2005 | 03:23 AM
Racetronix's Avatar
All these questions are addressed in detail on our web page here:
http://www.racetronix.com/Racetronix..._Pump_Kit.html
You should also consider picking up the Nov '05 issue of GM High Tech Performance as there is a full article in there covering the installation of the F-LT1 system and injectors.
Old Oct 20, 2005 | 04:57 AM
LameRandomName's Avatar
Reader's Digest Version:
The factory should have used fatter wires. The kit corrects that shortcoming.
Old Oct 20, 2005 | 08:34 AM
BlackScreaminMachine's Avatar
I bought my racetronix kit over 2 years ago, I finally had the need to install the new unit, and it rocks!! I still have to install the harness, but at this point its not "needed" and im too busy to far around with it.
But I will be doing it this winter, as with my cam swap.
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
form94
Sep 23, 2015 07:30 AM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
