Whats the difference in these pushrods?
Old Feb 23, 2007 | 07:01 PM
speed_demon24's Avatar
I'm probably going to need new pushrods for my car since my heads are getting milled and I'm going to be running a thinner head gasket. Whats the difference between the trickflow, comp magnum, and comp hi-tech pushrods? They are all .080 wall heat treated chromoly, but there is a pretty big price difference in them.
Old Feb 23, 2007 | 11:31 PM
buzz12586's Avatar
Yea I was flipping through the Summit catalog and wondering the same thing.
Old Feb 24, 2007 | 01:26 AM
seawolf06's Avatar
Comp Hi-tech = Trickflow = Manley > Comp Magnum
That's just what I read.
Old Feb 24, 2007 | 02:00 AM
Where'd you read that, I did a search and can't find anything.
Old Feb 24, 2007 | 02:15 AM
MachinistOne's Avatar
They are all basically the same thing, I use the Manley's because we are WD with them and I get better prices than the trick-flow's or comps.
SS RRR's Avatar
Not sure if that's true, but I wouldn't be surprised. Lots of parts companies "outsource" and stamp their brand name on it. From what I've heard from a machinist the Melling and Moroso oil pumps are made by the same manufacturer.
Old Feb 24, 2007 | 07:44 AM
Javier97Z28's Avatar
Moderator
If I recall correctly the Moroso oil pumps even have the the Melling part #'s stamped on them.
Old Feb 24, 2007 | 07:50 AM
mdacton's Avatar
The summit pumps are also melling, have had both of them and they both have the melling number on them.
BTW I think the summit pushrods are made by trickflow....or they are both made by the same company
Old Feb 24, 2007 | 11:27 AM
seawolf06's Avatar
Trend makes most of the name brand pushrods out there.
Old Feb 24, 2007 | 11:37 AM
Koby's Avatar
Actually the majority of summits parts are made my trickflow, melling, etc. they just stamp the Summit name on them and sell them cheaper than actual brand name. So if you are looking for a set of pushrods, check out the Summit Chromoly ones, they are only 80 bucks and as the guy stated above, probably made by Trickflow.
Old Feb 24, 2007 | 12:04 PM
buzz12586's Avatar
Would the summit ones be just as good as the Comp ones??
Old Feb 24, 2007 | 12:15 PM
mdacton's Avatar
I personally would say the higher end summit ones are equal to them....they are .083 wall.....
Old Feb 24, 2007 | 12:58 PM
SStrokerAce's Avatar
Depends on the wall thickness and if the tubing is seemless or not. Seemless tubing for pushrods is preferred because seemed tubing has unequal wall thickness which will cause the pushrod to bend a certain way everytime to the week spot in the pushrod, not good.
Bret
Old Feb 24, 2007 | 01:28 PM
Bret
Would all the one piece ones be seemless?
Old Feb 24, 2007 | 01:46 PM
No.
Comp's 3 levels, the middle one is not seemless and the top level (Hi Tech) is.
Usually they will specificly say they are seemless tubing.
Bret
