whats difference le1 HL and le1 1.5?
Old Dec 18, 2007 | 08:00 PM
ztwenty8's Avatar
just like the title states.
i figured i wanted to do the le2 heads. but not really a high reaving cam. so i figure get most power out the cam. buy if someone can explain more in detail which would be the ideal way to go
thanks in advance
mike
Old Dec 18, 2007 | 08:26 PM
wrd1972's Avatar
The LE1.5 cam has the same intake/exhaust duration as the LE1 cam. However the LE1.5 cam has a bit more lift which will build a bigger torque curve and make it lope a bit more.
I rev mine to 6.3K RPM but it could rev even higher, it does not appear to fall off. I am still awaiting the dyno tune to see what the curves really look like.
Both cams want to rev to around 6.3K or so. Both are great cams, but the LE1.5 will beat the springs a bit harder which must be monitored.
Brett Bauer has made the statement to me that this cams power is very close to the LE2 but does not have to rev as high. I have this cam and LE2 heads, I did not want to rev to the 6.5K+ RPM range. No regrets.
Old Dec 18, 2007 | 08:36 PM
ztwenty8's Avatar
im just wondering if its really the same cam just two different names for it? kinda sounds like it
Old Dec 18, 2007 | 08:40 PM
wrd1972's Avatar
Did you even read my post. I clearly stated that the LE1.5 cam HAS MORE LIFT than the LE1 cam. The Durations are the same. This clearly means it is NOT the same cam.
Old Dec 18, 2007 | 09:02 PM
ztwenty8's Avatar
sorry, i think you misunderstud my question, i know that there is the regualar le1 cam. i was refering the the le1 HL cam. i was told the HL stood for "high lift" and from it sounds like that le1.5 and the le1 HL are the same both with bigger lift
sorry if there was any misconfusion
Old Dec 18, 2007 | 09:05 PM
wrd1972's Avatar
Whoops my bad.
I know the specs of both, they are practically identical. Only a smidge different on lift, and I mean a smidge. You are correct, that are nearly the same cam.
Hope that helps.
Old Dec 18, 2007 | 09:09 PM
ztwenty8's Avatar
lol, its all good
ok good thats what i was thinking. so either one will be just what i needed. thanks for your input wrd 1972
Old Dec 18, 2007 | 11:09 PM
tireburnin's Avatar
The difference is marketing. People get to feel special and write sub numbers to differentiate thier setups.
Old Dec 18, 2007 | 11:12 PM
slomarao's Avatar
if you dont want to rev the motor up to 67-6800rpms than have llyod make the cam peak earlier. Like 6400, he ll make whatever you want. You just will be giving up some hp thats all.
Old Dec 19, 2007 | 02:35 PM
wrd1972's Avatar
Cant you accomplish this by just getting the LE1 type cam, ~6400 is where it wants to rev to by design.
Old Dec 19, 2007 | 04:03 PM
Dave1980's Avatar
OK, I am sure that Lloyd just makes the other #'s up to confuse and market, and make people feel special.
Old Dec 19, 2007 | 04:18 PM
SS MPSTR's Avatar
You say that like its difficult to comprehend.
Old Dec 19, 2007 | 04:42 PM
NightTrain66's Avatar
I think most people know better than that, lol.
biggest diferencence is that the LE1 cam is made to work with springs on the LE1 haeds, the LE1 HL cam has the same duration but more lift requiring the bee hives and the LE1.5 is a cam with the duration closer to the LE2 cam and still needing bee hive springs.
This really only matters when buying a used cam or a cam from the for sale section. If buying a new cam from me, we will go over your set up and get you the cam that will work best with your gear, weight, stall, shift RPM, springs used, etc.
Lloyd
Old Dec 19, 2007 | 08:24 PM
SS MPSTR's Avatar
My point was that it is all marketing. Really, why even advertise a LE1.52343452 or LE3.2 if you tailor the parts/cam/portwork to the application? I'd certainly hope you tailor the cam and valvetrain to the application.
Old Dec 20, 2007 | 08:28 AM
wrd1972's Avatar
