whats the diff between vented and nonvented opti's
Old Sep 25, 2006 | 08:24 PM
4SFEDZ's Avatar
my 94 i beleive came with a nonvented opti can i run a vented? the vented are cheaper and seem more durable. i need to buy a new one and need some info!
Old Sep 26, 2006 | 12:13 AM
Craddock's Avatar
Re: whats the diff between vented and nonvented opti's
Wow, for someone with so many posts and so many mods to your car I'd think you'd know better than posting this question in this instead of lt1, and you should know if you have a vented opti or not.
You don't by the way.
Old Sep 26, 2006 | 04:18 AM
01Z's Avatar
01Z
Changing to a vented optispark is an involved process compared to some modifications. I have a the instructions on how to do it, saved in a file but so far I don't have a link to give you. Here's some information on the differences between the two.
http://www.gmhightechperformance.com...ing_modifying/
Old Sep 26, 2006 | 08:12 AM
Sweetred95ta's Avatar
You have to have a different timing chain cover, a different length dowel pin on your cam, and all of the vent tubes to go to your intake bellow and intake. You will also need that fitting that goes into the bellow and you'll have to drill a hole. I think I covered everything. I've never had to worry about it.
Old Sep 26, 2006 | 08:15 AM
playa7970's Avatar
i got a vented opti up for grabs let me know if your interested it has 1,500 miles on it ill let it go for 130
Old Sep 26, 2006 | 12:35 PM
4SFEDZ's Avatar
your so kind, i SAID i had a novented, thanks for the help!
Old Sep 26, 2006 | 12:36 PM
4SFEDZ's Avatar
is it worth the trouble to switch?
Old Sep 26, 2006 | 02:24 PM
playa7970's Avatar
its worth it for reliability and about 10 extra horses if you go with a electric wp
Old Sep 30, 2006 | 10:09 PM
Severous01's Avatar
i dont think it's worth the trouble...unless you have a newer intake manifold and are doing a head/cam swap any way. which wouldnt be too hard to do...just order a 96-7 cam and get a new cover...double roller and some new rockers.... .....sorry...off topic.
you could do all this at once with a head/cam swap and not worry about doing it again when you want to change heads/cams.
Old Oct 1, 2006 | 01:18 PM
sbs's Avatar
sbs
No. Buy one of the aftermarket vented 92-94 replacements.
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 10, 2015 02:23 PM
