What's a Crankcase Evacuation kit?
Old Dec 17, 2002 | 09:15 PM
Gripenfelter's Avatar
Like the topic says.
What's a crankcase evacuation kit?
Old Dec 17, 2002 | 09:27 PM
Ai's Avatar
Ai
Tries to kill the positive crankcase pressure and pull vac like a dry sump.
Old Dec 17, 2002 | 09:30 PM
Josh-'04 GTO's Avatar
Its a couple of fittings that get welded to your exhaust system, with 2 more fittings in the valve covers. The exhaust flow then pulls crankcase pressure out of your engine, thus reducing pressure working against the rotating assembly. Usually used on high RPM race motors. I have one friend that used it on a powerful big block, but it does puff some smoke out the tailpipes. I wouldn't use it personally on any of my cars, and never on a street car.
Old Dec 17, 2002 | 09:53 PM
chucks97ss's Avatar
We're going to be using the stock air pump to pull pressure out of my motor... (just an idea for you)
Later
Chuck
Old Dec 18, 2002 | 08:48 AM
CANTONRACER's Avatar
I will have it next year on my street car. I will have to watch the oil more often, but I check it all the time anyway.
It is supposed to free up power. Many people I have talked to say you can get a 1/10 ET drop, that is on fast cars, so maybe more for slow folks like the most of us.
I will be doing mine a little differently. I will run the breathers from the valve covers into a "T", and from that to the y-pipe, so I only have to have one fitting to weld.
Old Dec 18, 2002 | 09:55 AM
red's Avatar
red
Later
Chuck
Do you know how many CFM's the stock unit will pull? Will it keep up with crank case pressure at high RPM?
Old Dec 18, 2002 | 10:01 AM
chucks97ss's Avatar
No, I'm not sure. My mechanic told me at one point though. He seemed to think it was adequate.... I can try to find out, or maybe someone else knows.
Later
Chuck
Old Dec 18, 2002 | 10:05 AM
One of my friends has it on his heads and cam LT1 350.
He has uncoated long tubes and true duals.
I was just wondering if it was worth the money.
Old Dec 18, 2002 | 12:25 PM
Anyone else?
Old Dec 18, 2002 | 02:43 PM
Thanx Chuck thats what I wanted to know.
Old Oct 8, 2003 | 03:22 PM
m0nk's Avatar
Why do you have to check your oil more often, does it really pull out that much oil? I've heard its suposed to help oil consumtion due to blowby...
lt1xondeck
Mar 18, 2016 07:22 PM
350350
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
