whats the correct way to adjust the valves with the motor off ??
Subscribe
Dec 23, 2004 | 11:47 AM
i installed the cc306 with cc lifters part#850-16 and springs part#26918-16 with 1.6 crane gold rockers i have a slight idea but just want to make sure so i dont over tighten them i have heard of lots of people doing that.just want to getit right.
Reply
Dec 23, 2004 | 12:21 PM
Re: whats the correct way to adjust the valves with the motor off ??
Give me your FAX number and I will send you a 1-sheet simple method.
Reply
Dec 23, 2004 | 01:09 PM
Do you have it in digital form (email)? Can I get a copy...or I'll PM you a fax number.
Curious what your method is.
Reply
Dec 23, 2004 | 01:27 PM
Instructions from Shoebox's site:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Reply
Dec 23, 2004 | 01:50 PM
Too many bits, bytes, whatever for E-Mail. I will FAX.
Reply
Dec 23, 2004 | 02:25 PM
hey bubba my fax number is 901-753-8302 ill be here to 7.00pm also do i have the comp r lifters by that part number thanks randy
Reply
Dec 23, 2004 | 02:40 PM
The Comp Cam 850 is for car which has hyd r lifters, so the answer is yes.
Reply
Dec 23, 2004 | 05:08 PM
well if thats the case would a half turn after 0 lash be to much should i come down to a quarter turn?
Reply
Dec 23, 2004 | 06:52 PM
Alot of people run the Comp R's an 1/8 past zero. But an 1/8 or 1/4 should be fine.
Brandon
Reply
Subscribe
