What's the Bolt size of the 3 Opti to Timing Cover Bolts
Old Dec 14, 2006 | 12:26 AM
ponyackn's Avatar
I used shoebox's site http://shbox.com/ci/fastener_matrix.html to find the specs on these 3 bolts. If I am looking at the right one on that page it states:
Optispark Mounting Bolt 106 lb. in. 3/8" 1/4"-20 x 2.75". I bought some grade 8 bolts in this size but they sit almost an inch too far out.
This is on a new lt1 383 shortblock. Initially, I tried to place the bolt in but there was too much rubberized rtv. I stuck a screwdriver in the holes to remove it and was then able to screw the bolts in. But all 3 bolts seem to stop nearly an inch away from where they should I can get plenty of thread or turns on the bolt. I'm figuring on just getting shorter bolts, but want to be certain that I'm not bottoming the bolts out on something else besides the block itself.
Old Dec 14, 2006 | 02:34 AM
Dave89IROC's Avatar
just get shorter bolts, 1.75 or 1.5 long ones
Old Dec 14, 2006 | 07:30 AM
That's the length my reference source say the bolts are. I guess there could be an error. Let me go pull an opti bolt and get back to you.
p.s. It may be a while.
Old Dec 14, 2006 | 07:42 AM
Sweetred95ta's Avatar
2.75" is way too long. I agree with Dave that they're somewhere around 1.5"-1.75" long.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
