whats the biggest DR
Old Feb 19, 2004 | 04:46 PM
NEOS97SS's Avatar
you can fit on 16x8s????
Old Feb 19, 2004 | 05:23 PM
z28_4life's Avatar
I've seen 245 nittos and 255 bfg drag radials. Other then that you'll have to go with a smaller 15 in rim or larger wider tire. Most of the companies make them for 15 in rims. Nitto does make theirs for larger tires but you're not gonna go much wider then that on a 8 in rim.
Old Feb 20, 2004 | 12:26 AM
QCKZ28's Avatar
Re: whats the biggest DR
drag radials: BFG is 255/50/16, NITTO is 245/50/16 the only size available for 16"
17" drag radials are available in 315/35/17 and a 275 size.
et streets are available in 26x11.5x16 and they will fit 16x8 wheels.
jesse
Old Feb 20, 2004 | 01:16 AM
atljar's Avatar
Re: Re: whats the biggest DR
jesse
Just FYI, those may take a tad bit of clearancing to fit. The BFH method worked wonders for me.
Old Feb 20, 2004 | 02:10 AM
QCKZ28's Avatar
Re: Re: Re: whats the biggest DR
even for us non-lowered folks?
jesse
Old Feb 22, 2004 | 12:00 AM
atljar's Avatar
Yup, even for the non lowered folks!
They hit the inside if the wheel well, kinda behind the top right of rotor if looking straight on.
Old Feb 22, 2004 | 02:16 AM
QCKZ28's Avatar
thanks jared, i will just get the 10.5" instead. that should be plenty of tire for my setup, what do you think?
jesse
Old Feb 22, 2004 | 02:31 AM
atljar's Avatar
The 10.5 will be plenty. Only reason i run the 11.5s is that they are a tad taller too which helps cut down my gear a little
The clearancing is really minimal though, im a freak about my car and keeping it in nice shape and i had no problem doing it.
Old Feb 22, 2004 | 02:41 AM
QCKZ28's Avatar
the part i would have to hammer would be right where the top folds down in to, space is very limited in that area on my vert....
Old Feb 22, 2004 | 02:44 AM
atljar's Avatar
True, you have less space. Im not sure how tight it is down there with the verts.
I would say you need to knock it in ~3/8 inch
WPHIG2
Aug 27, 2015 06:37 AM
whitehooptie
Jul 12, 2015 06:10 PM
jackpawt883
May 21, 2015 12:34 AM
blkWidow
Apr 20, 2015 09:27 AM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
