What are your thoughts, or better yet, your experiences with the Z06 85mm MAF?
Old Oct 13, 2002 | 03:35 AM
sfGi8nt's Avatar
I was doing a little bit of research in the Search Forum and ran across someone who had seen a decent gain with the Z06 85mm MAF.
I was wondering if anybody else has heard about it, or has one?
What do you think of it? It says its worth 18rwhp, but whats that in real life, anybody see 10rwhp, or a tenth at the track with one?
Any info on the subject would be great!
Old Oct 13, 2002 | 04:55 PM
sfGi8nt's Avatar
WOW..nobody has one, or knows how they are, or NOTHING?
I', interested in this guys!
Help me out.
I did a search but only came up with 2 threads.
Old Oct 13, 2002 | 07:03 PM
97FormulaWS-6's Avatar
I don't know about a power increase, but thats due to a horrible Opti studder that's developed since I installed the Z06 MAF, so I can't really tell any power difference. I know it's not the flowcharts because I've got all my BLMs at approx +0-+3. Mainly it's a cheaper replacement for a stocker than a Factory ($300) or Grantelli ($320), whereas the Z06 is only $80 shipped. The only thig is that you've got to repogram the Flow Vs Frequency chart in the PCM.
Mike
Old Oct 13, 2002 | 07:24 PM
sfGi8nt's Avatar
Mike
Hmm..I just did anpther search and found more threads than before (I dont know why, but it helped)
I understand your the guy who is editing all of yours, while others are buyin it from LS1.Speed ready to put in for $150
One question now. does this replace the stock MAF (like take off the stock one and put this one in)?
Or, do you "piggy-back" the stock MAF with the z06 MAF?
Just wondering,
thanks
Old Oct 13, 2002 | 07:36 PM
Koby's Avatar
It is a complete replacement for the stock MAF. When I put mine in I noticed it right off the bat. The car is more responsive, better throttle response, and it pulled harder up past 60. First mod I have done to my car that I actually noticed.
The pcm will relearn the MAF, for the best benifits you need a custom tune, but all you have to do is unplug the battery and it will have full effect.
Old Oct 13, 2002 | 07:42 PM
sfGi8nt's Avatar
Ok, so how long do you have to "take it easy" so the pcm can learn about it?
Also, by unplugging the battery, do you still have to take it easy on it? Or will the pcm know off the bat?>
Old Oct 13, 2002 | 08:52 PM
RedLineRev's Avatar
will this Z06 MAF out perform a ported one, or just is better than a stock one???? I am also in search of this topic. Help us out someone.
Ryan
Old Oct 14, 2002 | 07:29 AM
The factory replacement Z06 MAF the computer will not Re-Learn... trust me if you look at the Flow Vs Frequency tabes for the 2 they're so different it's not even funny. I had a very close to factory program in and my car ran so rich it was throwing codes in about 30 mins, all the BLMs were pegged rich.
It is a full replacement, but is larger. The factory one is a 72mm (I believe) and the Z06 is 85mm. This also makes it a little interesting on install because the "In" side is a 4" Diameter, and the "Out" side is a 3.5" It "should" out perform a stock or ported one, but like I've said before I haven't been able to tell due to other problems that have arrisen.
Old Feb 22, 2003 | 05:20 AM
cndctrdj's Avatar
ya i was thiniking about this also. i had read a while back about it but not much came from it. has anyone since then tried this out?
Magenta_Hearts
Mar 29, 2017 08:54 PM
maybe2fast
Mar 13, 2015 11:48 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
