What are your seat pressures?
Old Feb 23, 2008 | 08:35 PM
mdacton's Avatar
What are you running on the seat for your hyd. cams?
Just wondering what everyone is running on average.....I'm about to try something
Old Feb 23, 2008 | 09:10 PM
11secgen's Avatar
im running 135 w/ the 847.
Old Feb 23, 2008 | 09:53 PM
Ken95Z28's Avatar
I'm running 165#. Had a pretty big Hydraulic cam in mine, swapping it out to a solid roller now. Hyrdaulic specs are 625/576 lift duration is 236/242. And get this I was running Comp R's and did not have a single one that failed in the past three years. I was expecting to see some broken but I found everyone to be perfectly fine.
Old Feb 23, 2008 | 10:02 PM
jimbob65's Avatar
175 @ 1.95 installed height.
450 or 475 psi (cant remember now) @ .6 lift
on stock lifters... never a problem...
Old Feb 23, 2008 | 10:19 PM
SS RRR's Avatar
ur **** is a turd.
Old Feb 23, 2008 | 10:42 PM
speed_demon24's Avatar
Originally Posted by SS RRR
ur **** is a turd.
[zrated94] You are a phony and your car doesn't exist [/zrated94]
Oh and to the OP it might help if you tell us what your valvetrain setup is going to be (cam and lobes, ect.)
Old Feb 24, 2008 | 06:41 AM
mdacton's Avatar
[QUOTE=speed_demon24;5203620Oh and to the OP it might help if you tell us what your valvetrain setup is going to be (cam and lobes, ect.)[/QUOTE]
Its all top secret, and not my car....I have 260 on the seat
But I was going to run a spring I used a long time ago that has a light seat but its strong open, its only 135 or so on the seat
Old Feb 24, 2008 | 06:03 PM
marshall93z's Avatar
PAC1218s at ~140.
1.75"
GM847
Old Feb 25, 2008 | 05:19 PM
carolinacasper's Avatar
Man your skinny. I'm 175. So my driver seat pressure is 175.
Old Feb 25, 2008 | 05:24 PM
mdacton's Avatar
Well checked the springs, they are more like 160# on the seat 430# open
Old Feb 25, 2008 | 05:44 PM
11secgen's Avatar
wait, that was a typo, i meant 185 lbs@ 1.78,385 1.20 and 465 at max vale lift.i had to check my spring card from p.s.i.
Old Feb 25, 2008 | 05:57 PM
jakesz28's Avatar
260 closed and 660 open. But it is a solid roller.
Old Feb 25, 2008 | 06:41 PM
mdacton's Avatar
yeah so thanks for nothing
Old Feb 25, 2008 | 07:50 PM
jakesz28's Avatar
Sorry had to dig thru some paper work 138# closed 325# open is what was in the old motor.
Old Feb 25, 2008 | 10:43 PM
truedualws6's Avatar
Check the Valve Spring Chart in my sig if you want to see a bunch of
common HR springs in use by the LT1 crowd. I'm using the Crane 96872s
at 1.82" closed and 1.27" open.
I still don't see the point in your vague question.
