what year out of 93-97 has teh biggest cam
Subscribe
Feb 13, 2003 | 11:41 AM
lobe speration, lift....
Reply
Feb 13, 2003 | 11:50 AM
im pretty sure their all the same. ive never heard of any changes made in the cams between years.
jon
Reply
Feb 13, 2003 | 12:14 PM
I'd say they are the same too, maybe the vette has a little bit of difference from the camaro/ta/firebird's ???
Reply
Feb 13, 2003 | 12:18 PM
Here is a list that I can't verify :
GM .450 .450 .480 .460 93 LT1 STOCK
GM 203 208 .450 .460 .480 .491 116 94-95 LT1 STOCK
GM 205 207 .447 .459 .477 .490 117 96 LT1 STOCK
GM 203 210 .446 .449 .476 .479 115 96 LT4 (STOCK
-Alex
Reply
Feb 13, 2003 | 12:29 PM
i thougth the 94-95 had the biggest, thanks
Reply
Feb 13, 2003 | 01:04 PM
This is a list I have compiled from my web page. Some have P/N - some I have not found, but these are all specs I have found from the web, and I hope to eventually find some more truth to them.
Apparently in some years the vette lt1 did get a different cam then the fbody lt1, and then there is the 265v8 in the caprices as well as the 5.7L Caprice Classic or Patrol car cam. Then we have the lt4... It just goes on. But here is what I've found. There is very little change aside from the 265cid motor, a few random ones, and then the lt4 and hotcam (and ls1 cams) If anyone has markups let me know, I'm still working on the site as we speak.
CAM____Duration___Lift(1.5)___Lift(1.6)____Lobe___ P/N
92 Vette_205/207__.451/.450__.???/.???___117____10168506
93 Lt1___xxx/xxx__.xxx/.xxx___.xxx/.xxx____xxx___10224241
93 Vette_205/207__.451/.450__.???/.???___117____10168506
94 Lt1___xxx/xxx__.xxx/.xxx___.xxx/.xxx____xxx___10224241
94 Vette_203/208__.450/.460__.???/.???___116____10168531
94 L99__205/207__.451/.450__.???/.???___117____10243779
94 ???__191/196___.418/.413__.???/.???___111____
95 Lt1___201/208__.447/.459__.480/.491__116____12551705
95 Vette_205/207__.451/.450__.???/.???___117____10168506
95 L99__205/207__.451/.450__.???/.???___117____10243779
96 Lt1___205/207__.457/.459__.477/.490__117____
96 Lt1___200/207__.447/.459__.480/.489__117____
96 Vette_205/207__.451/.450__.???/.???___117____10168506
96 L99__205/207__.451/.450__.???/.???___117____10243779
96 Lt4___203/210__.446/.449__.476/.479__115.5__12551142
97 Lt1___
97 Lt4___
97 Vette_201/210__.472/.478(1.7rollers)___116____??????
98 Ls1___201/210__.500/.500(1.7rollers)___116____??????
98 Vette_202/210___.472/.479(1.7rollers)___116____??????
ZZ3_____208/221__.474/.510__.506/.544__112____
Lt1 H/C__218/228__.492/.492__.525/.525__112____24502586
Ls1 H/C__
Reply
Feb 13, 2003 | 02:11 PM
I hope your not buying a car based on this, they are so close its not even worth wondering about other than curiosity. If it has more lift, it will have less duration, and so on.
There is also the LT4 cam which I think was a 203/210 but I can't recall for certain. Ok, and it was posted above...
Reply
Feb 13, 2003 | 02:27 PM
Check out www.ws6.com, they have the specs for each year listed in the FAQ section under engines I believe.
Reply
Feb 14, 2003 | 11:53 AM
I am not buyig a car on this, I am doing a speech and need the info
Reply
Subscribe
