what year lt1
Old Feb 23, 2011 | 07:26 PM
DoinItMovin707's Avatar
what year lt1
ok so i bought a lt1 off someone that told me it was a 1996 lt1 out of a corvette with 60k on motor and it came with the pcm for $500 but when i got it home and really started lookin at the motor i noticed it didnt have alum head so i know its not out of a vette and since he lied about what car it came out of im thinkin its not a 96 motor either so how would i tell what year lt1 i have?
Old Feb 23, 2011 | 07:49 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: what year lt1
I believe the only lt1s without aluminum heads are the ones out of the caprices
Old Feb 23, 2011 | 08:02 PM
Kevin Blown 95 TA's Avatar
Re: what year lt1
If it has a crank sensor on the timing cover, it's a 96 or 97. If not, it's 95 or earlier. If it has a rectangular ALDL connector and not a D shaped one for the diagnostic connector on the wiring harness, it is probably a 94 or earlier, if the PCM has a cal chip and the fuel rail doesn't have a cross over tube in front, it is probably a 93.
Old Feb 23, 2011 | 08:14 PM
Re: what year lt1
well it didnt come with the wiring harness
Old Feb 23, 2011 | 08:25 PM
bw_hunter's Avatar
Re: what year lt1
It's easy without the wiring.
93 fuel rail does not cross over the top front of the intake and the fuel lines attach near the DS center of the manifold.
94+ the fuel rail crosses T the top front of the intake
94 the distributor is not vented so there are no vacuum lines or ports on it.
95 the distributor is vented with hosed and ports
96 + 97 add a sensor to the timing cover (CPS) to the 95 setup.
Old Feb 23, 2011 | 08:35 PM
Re: what year lt1
thanks for the run down
Old Feb 23, 2011 | 09:34 PM
Re: what year lt1
With iron heads, it would have come out of a B or D body. They all had vented optis.
I'll bet this VIN derivative year designation would be the same as the f-body.
Old Feb 23, 2011 | 09:53 PM
Re: what year lt1
thanks shoebox i will check the block tomorrow for those numbers
Old Feb 24, 2011 | 08:27 AM
Wild Willy's Avatar
Re: what year lt1
This. The B-body, for whatever reason, got the vented opti first- Also, the iron heads actually flowed much better than the aluminum ones, and produced great torque. If it is a B/D body LT1, it has a slightly different camshaft, too- again, tuned for torque rather than absolute H.P.- stock rating was 260 H.P., 330 ft/lbs -
Old Feb 24, 2011 | 12:26 PM
ZZ's Avatar
ZZ
Re: what year lt1
Hopefully it's a 5.7 too, and not the 4.3 LT1.
Old Feb 24, 2011 | 02:10 PM
Re: what year lt1
and how would i tell if its a 4.3 lt1 or a 5.7 lt1
Old Feb 24, 2011 | 04:05 PM
RamAir95TA's Avatar
Re: what year lt1
Look on the back of the block, driver side top. 5.7 or 4.3 should be cast into the block, just above the transmission bellhousing mounting flange.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
