What Ya'll Think Rwhp#'s Will Be?
Old Nov 6, 2003 | 10:28 PM
95Z383's Avatar
I'M BUILDING A 383 STROKER
FORGED PISTONS, CRANK, AND RODS
254 - 260 SOLID ROLLER WITH 1.7RR'S
ON 111 DURATION LIFT WILL BE .652 - .658
PORTED STOCK HEADS AND INTAKE TO MATCH
30LB. INJECTORS 58MM THROTTLE BODY
CONVERTED OVER TO FOUR BOLT MAIN WITH SPLAYED MAIN CAPS
LT1 EDIT AND A M6
JUST LOOKING FOR SOME GUESSES
IDEAS WELCOME
Old Nov 7, 2003 | 11:05 AM
Antz97ZNJ's Avatar
mid to high 300's...
Old Nov 7, 2003 | 12:29 PM
FastWhiteTA's Avatar
I say 410-420 rwhp and about 390-400 rwtq.
Old Nov 7, 2003 | 01:04 PM
Grease's Avatar
There are several important things to consider, like flow numbers on the heads, compression ratio, tuning and exhaust. If done right you could see as much as 450+rwhp.
Old Nov 7, 2003 | 01:41 PM
S.J.S.'s Avatar
I'd guess in the low to mid 4's assuming you have whats not listed.....headers, converter...etc.
Old Nov 7, 2003 | 02:00 PM
IslandZ's Avatar
And if it's not enough for you, with that bottom end you can spray another 175 RWHP easily!
E-Dogg
Aug 5, 2003 07:27 AM
