what would you do (bottom end rebuild)
Old Sep 21, 2004 | 03:11 PM
FormulaLT-1's Avatar
I'll make this quick, I installed a 847 on a 4 bolt 35,000 mile crate, and it spun a main and a rod bearing.
so the motor is pulled, and completely torn down and I'm sitting on it. I have about 1000-2000 bucks to work with. I still just have stock heads.
I'm not sure if I should just do a good 355 bottom end with some good bearings so i can spin it, try to do a ****ty 383. I need to build something that will last and do some good long highway miles, the car is more about mountain driving then drag racing.
Hopefully I'll do something soon, thanks for the input.
Old Sep 21, 2004 | 03:17 PM
trans9_5am's Avatar
Re: what would you do (bottom end rebuild)
What rpm's were you turning the engine to with the 847 in?
Brandon
Old Sep 21, 2004 | 03:22 PM
7k about 6-10 times.
Old Sep 21, 2004 | 03:53 PM
Compstall's Avatar
LOL, what did you expect?
Old Sep 21, 2004 | 03:59 PM
30696bird's Avatar
I'm not sure but, I think the cost of building a 355 and a 383 are pretty close to the same.
Old Sep 21, 2004 | 04:21 PM
dmoor88's Avatar
with that big of a cam id go with a 355
Old Sep 21, 2004 | 10:21 PM
mrz28 73/97's Avatar
I'd build a 383 using a Scat 9000 crank Scat 6" 4340 forged I beam rods and Speed Pro/TRW forged pistons with that cam and do some minor head work (bowls gasket matched ports & valve job) and then you'll really fly.
Old Sep 21, 2004 | 10:37 PM
1racerdude's Avatar
Whatever you build get Clevite "H" series brgs.They ain't cheap but you won't spin them at any RPM--If you have proper clearances and oil pressure--.
If you can come out with a .010-.010 crank and 1 rod,brgs and rings,I would build what I had and make the best of it.Don't put Molly ring's in it either,they are good for my lawn mower or tow truck.
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Killer94z
Jan 13, 2015 12:06 PM
RichJ
Sep 26, 2002 09:43 AM
