What would be more cost effective?355,383,396...
Old Feb 2, 2004 | 02:37 PM
bowtieforpower's Avatar
i want to add a lot more hp for the cheapest $ what would be better for the money? a 383/396 stroker, a blown 355, or changing my lt1 to a lt4 with ported heads/intake? or if anyone knows anything else, all ideas are welcome. thanks.
Old Feb 2, 2004 | 02:43 PM
FacelessZ's Avatar
LT1 -> LT4 is expensive and not really worth it unless you have the cash...
A lot of people are simply picking a cam to match their stock ported LT1 heads...
I'm currently researching into honing my block to 355, prepping and polishing my stock crank (honing to 355 and preparation of the stock crank, I've seen, run ~$200) and going forged with the rest of the internals and possibly hitting it with a 150-175 shot...
Ported LT1 heads and a matching cam will give you a lot of top end power and doesn't run a whole lot of money (~$400 for porting of your stock heads and ~$200 for a new or used camshaft)...
Old Feb 2, 2004 | 02:46 PM
well i have the lt4 hotcam kit installed right now. should i just port my lt1 heads then? what do you think about a turbo setup?
SVT Killer LV's Avatar
polishing the crank, but some H beams and some nice light forged pistons, port the heads, get a matching cam.. and slap a 300 shot on that (just in case )
Old Feb 2, 2004 | 02:48 PM
bottles are for babies!
Old Feb 2, 2004 | 02:50 PM
I can give you 503/560 reasons why bottles are for men
FacelessZ's Avatar
Yes email Lloyd: NightTrain66@msn.com
He can practically port match your LT1 heads to your hotcam...he'll give you more mid-lift numbers (~.200-.450") instead of high-lift (.550-.600")
Old Feb 2, 2004 | 02:53 PM
FacelessZ's Avatar
Trust me man, I used to think the same way. Do more research on N2O and you'll get a new found respect for the stuff. I've never personally used it, but if you've ridden in a car that was spraying...
I wouldn't advise messing with it unless you knew what you were doing...incorrect intstall can blow your rings...
Build your top end and then your bottom end...
cool, thanks. and bottles arent for men, they are for babies, real men get blown!
Old Feb 2, 2004 | 03:25 PM
Grease's Avatar
I like naturally aspirated engines. Chicks dig vacuum
Ported stock heads and a cam on a 355 with the stock crank, H-beam rods and forged pistons is the cheapest way to go. and you can spray it if you want to. But if you want to go with a supercharger, you can now buy a turbo kit for the LT1s cheaper than buying an intercooled supercharger kit. Better torque curve and no belt.
Old Feb 2, 2004 | 03:28 PM
Antz97ZNJ's Avatar
ls1 speed has a pretty inexpensive 355 long block...forged, etc....If I was to do it id go w/ 355
Old Feb 2, 2004 | 04:35 PM
blown guys always whine
Old Feb 2, 2004 | 04:37 PM
werd... "boost without the belt"
Old Feb 2, 2004 | 05:06 PM
Aries's Avatar
you NA boys always say things like that
Old Feb 2, 2004 | 05:19 PM
Fast96WS6's Avatar
I'd rather be Stroked and Blown
