What would make a car do this>>>
Old Jun 4, 2006 | 06:17 PM
F(ast)-body's Avatar
car starts and runs like a champ, then after about 20 minutes it starts backfiring and missing like hell....practically undriveable. Park the car and turn it off for abbout 20 minutes are so and it starts back up and runs great again for 15 minutes or so then starts missing and backfiring again......what the heck?? Opti is 4 years old but only has maybe 5000 miles on it....though they are mostly racing miles..
Old Jun 4, 2006 | 06:23 PM
wrastler's Avatar
Re: What would make a car do this>>>
Mine did that...it ended up being a broken plug wire
Old Jun 4, 2006 | 06:49 PM
really, didn't think of that. I have a set of OVC Taylor's on the car. Just don't know why one of them would all of a sudden "break".....How did you know it was broken?
Old Jun 4, 2006 | 06:51 PM
joeSS97's Avatar
Take an ohm meter to them.Twist the ends some when you do it,it will help find a break.
Old Jun 4, 2006 | 06:54 PM
sbs's Avatar
sbs
O2s
Old Jun 4, 2006 | 06:59 PM
Originally Posted by steve9899
O2s
thought of that one too, put new O2's on the car maybe 2 years ago....cars runs rich though, would that have killed thems so quick?
Old Jun 4, 2006 | 08:02 PM
1racerdude's Avatar
2yr old O2's may have gone bad.
Old Jun 4, 2006 | 09:19 PM
should I eliminate the idea that it could be the opti? What makes me think it's not is that the car does run perfectly fine for like the first 20 mins or so then it goes to crap....I figure with a bad opti it would run bad from the minute I start the car
Old Jun 4, 2006 | 09:39 PM
1racerdude's Avatar
True,maybe. Ya got to figure heat into the factor.
But it seems to run bad when it goes into closed loop so the O2's would be a good starting point.
Do you have access to a scanner and not just one for the trouble codes?
Old Jun 4, 2006 | 11:29 PM
streetwarrior96's Avatar
Same here, burned plug
Old Jun 4, 2006 | 11:52 PM
whitehooptie's Avatar
Unplug both o2's and drive around for a while. If it still does it, then it is not the o2's.
There I made my post that the board told me to make!
Old Jun 5, 2006 | 09:02 PM
won't it run like crap with the O2's unplugged?
Old Jun 5, 2006 | 09:20 PM
Honda Hunter's Avatar
If your o2's are to blame then you should see no change. A laptop and datalogger would be easier and would tell you alot more. Just rule out stuff one by one before you buy parts and one thing I learned is it doesnt matter if you installed something new 2 years ago or 2 hours ago dont think it cant be deffective or crapped itself.
Old Jun 5, 2006 | 10:48 PM
sam pace's Avatar
sounds like your coil is going bad.
usually your dead giveaway is the bad miss when it warms up.
once it colls down it runs fine again.
Old Jun 6, 2006 | 12:20 AM
No, it'll go back to default. It'll run rich, but should still run with no hesitation.
I had a problem similar to this. One of my o2's were to blame. I unplugged it, drove around for a while. Drove fine. Plugged it back in, and I found my hesitation.
