What would be the effects of a failing Throttle Postion Sensor and Engine Coolant Sen
Old Mar 15, 2004 | 12:00 PM
LeeS's Avatar
Question What would be the effects of a failing Throttle Postion Sensor and Engine Coolant Sen
Hi Guys!
I have a 1997 Z28 with 79 K miles on it what would be the effects of a failing Engine coolant temperature sensor and a Throttle Position Sensor.
My car studders at idle or pops a little in the exhaust idling.
Would bad Tps or ECT Sensor cause this?
I have replaced plugs and Wires, Optispark, Ignition Coil and Module. EGR Valve.
Thanks Lee!
Old Mar 15, 2004 | 12:05 PM
A bad ECT in the water pump could feed the PCM poor info and cause the car to run rich. A bad TPS would cause different types of drivability problems. Best/quickest way to know if they are both ok is with a scanner.
Old Mar 15, 2004 | 03:20 PM
LeeS's Avatar
Thanks Shoebox for your help!
Lee!
Old Mar 15, 2004 | 04:12 PM
Don 97 SS's Avatar
I had another vehicle that had a bad TPS. The engine RPM would hunt up and down at idle from below normal idle speed to much higher RPMs. It was like it was possessed The engine would pop or hiccup some.
Old Mar 15, 2004 | 10:40 PM
LeeS's Avatar
Thanks Don for your help I really appreciate it.
Lee!
HectorM52
Jul 30, 2017 11:46 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
