What would cause a cat to glow red?
Old Oct 4, 2003 | 10:37 AM
MonkeyManZ28's Avatar
Old Oct 4, 2003 | 10:42 AM
Seal's Avatar
extreme heat...
i'm talking 1K+ here
Old Oct 4, 2003 | 11:15 AM
ChuckZ28's Avatar
I wonder if your cat might be clogged? you might want to check that out because if it is your motor will be at serious risk.
Old Oct 4, 2003 | 11:24 AM
RENE95Z's Avatar
I agree with ChuckZ28. May be a clogged cat. Have you been experiencing a loss of power lately. This will also be a symptom.
Old Oct 4, 2003 | 11:33 AM
Fastbird93's Avatar
Running Really rich, clogged cat are the two things that come to my mind.
Old Oct 4, 2003 | 12:52 PM
wicked_95z's Avatar
Are your manifolds/headers glowing as well? If not I would say clogged cat.
Old Oct 4, 2003 | 12:55 PM
wicked_95z's Avatar
Are your headers/manifolds glowing red as well? If not I would say clogged cat.
Old Oct 4, 2003 | 10:12 PM
Fatdog's Avatar
Unhappy
Sounds really dangerous.Please get this checked asap.My02
Old Oct 4, 2003 | 10:54 PM
AxeGrinder30thZ's Avatar
Originally posted by aggiez28
omg what the hell were you feeding it??????
Haha! LMFAO!
Old Oct 5, 2003 | 12:59 AM
Buttercup's Avatar
Usually a glowing cat means both excessive air and fuel present in the exhaust. If the engine is simply running rich, it will actually cool the cat(s) and if it's running lean it still won't experience such elevated temps. Most probable cause for such a condition is an exhaust leak or an ignition problem.
If it is a "clogged" cat you will lose performance, many times the cat will rattle when tapped, and sometimes you will actually here it hiss under heavy load. Many times the cat will clog because of failure related to the conditions above. If it is simply replaced without fixing the underlying problem it will meltdown all over again.
Critter
Jul 7, 2015 08:33 PM
May 15, 2015 10:43 AM
Collector Car
Dec 17, 2014 01:12 PM
Dec 1, 2014 08:08 AM
