What will she run?
Old Dec 2, 2008 | 01:20 PM
84zed's Avatar
What will she run?
I`m hoping for 12`s but since I won`t be able to find out till next year I thought I would ask for some opinions.It`s a 95 Z28 with cai,52mm t.b.,
mildly ported stock heads,hot cam 1.6r.r.,bbk shorty headers,high flow cat,
mac catback,2200 stall converter,3.42 gears,245/50 drag radials 3700lbs.
Just wondering what it should run in the 1/4 and what it should put out on the dyno.
Old Dec 2, 2008 | 01:33 PM
'94 Bad A Z28's Avatar
Optimistically you can hope for 320-340rwhp with a little less torque. Then hope for a 12.7-12.9 with a good launch. If I were you I'd try to get at least a 2800 stall in there. A 2200 stall is basically a stock stall converter, because it will only break torque to 1600-1800 just like a stock converter and it should flash somewhere in the 2100-2300 plus or minus 100rpm just like a stock converter.
Old Dec 3, 2008 | 07:57 AM
93transam1234's Avatar
High 12's with a good launch, might touch mid 12's on a perfect run with the car in perfect running condition.
Old Dec 3, 2008 | 09:11 AM
cblinkdude182's Avatar
With the drag radials, if you can launch, 12's should be no problem for you.
Old Dec 3, 2008 | 09:49 AM
bombebomb's Avatar
This post scared me at first, but I see he is running shorties and a smaller cam. Id agree with everyone here, them shorties are hurting you id say.
Old Dec 3, 2008 | 12:21 PM
<Puck>'s Avatar
How ported are your heads? What's your tracks DA? I personally don't see quicker then high 12s without more stall.
Add 3.73s and a 3200 stall and I could see 12.5s if you can hook, but I would guess 12.8-12.9 as-is
Old Dec 3, 2008 | 02:51 PM
Agreed
Old Dec 10, 2008 | 07:19 PM
sn8ke eatr's Avatar
id agree and say high-ish 12's. longtubes/ory, and bigger stall would probably put you at 12.5-6 on a good day
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
