What will i run
Old Jul 31, 2003 | 11:57 AM
kaoticcamaross's Avatar
What will i run
I just got some hooker long tubes, 52mm throttle body, slp cold air intake, slp loudmouth exhaust, lt4 hot cam kit with everything, some nitto 450, custom pcm, and 160 thermostat. What should i exspect to run?
Old Jul 31, 2003 | 12:02 PM
clownhair's Avatar
I would bet you will be in the 12's.
Old Jul 31, 2003 | 12:12 PM
Brettinator's Avatar
What's up Wes? Your car would run a very low 13 or maybe high 12's but gears would really help you capitalize on it's full potential. I'd also consider a torque converter. Shop in Galveston does a lot of TransKing for the stroker cars, or a Vigilante would be good too. Are you doing roller rockers with your hotcam setup?
Old Jul 31, 2003 | 02:39 PM
amean94ta's Avatar
somewhere between 10's and 16's
Old Jul 31, 2003 | 03:39 PM
97WRAITH's Avatar
You should be in the 12's with a good tune and some sticky tires.
Old Jul 31, 2003 | 03:46 PM
Teal94Z's Avatar
If you can drive, high 12's
Old Jul 31, 2003 | 05:21 PM
hey brett I'm doing good. i just got some 3.42's i forgot to tell you about so add that into the time. Yea the kit for the lt4 hot cam is rockers, cam, timing chain, all that ****.
Old Jul 31, 2003 | 08:20 PM
well I got mine running right again with new 02 sensors. I'm gonna have to come over and run you again after all your goodies are in....I'm still saving for what I have planned ...I'm going overboard but I can't help it
Old Jul 31, 2003 | 09:28 PM
Transamdriver's Avatar
Faster than when you were stock.
Old Jul 31, 2003 | 09:43 PM
kevinsz2895's Avatar
i'd bet on mid 12's but i og tsometihng to putmyu a little more lower
an NOS kit
Old Jul 31, 2003 | 09:45 PM
i got some fat fingers but i got a NOS kit i will sale to get you out if the 12's
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
