what will i need (jethot y-pipe)
You wont really be able to keep you cat in the stock location, You will be able to cut the stock cat-back to fit, will have to either have it welded into place or have the cut end flared and clamped over the y pipes outlet,I would have it welded into place.
If you have to pass emissions before you go to Germany then I would wait with the install. Because you won't pass them anyways. You'd need to have SMOG legal headers to pass emissions. Unless you know someone on the inside. If I were you I'd just wait with that install.
