What will I need to cut a 1.7 60ft.
Old Nov 14, 2006 | 09:58 PM
Maro Boy Ken's Avatar
With normal weight + minor things like my tv and dvd player taken out rear seats... What will it take for me to get to 1.7's. in the 60ft.
I have a 6 spd with 4:10's im guessing a nice 33 spline 12 bolt will help.
Old Nov 14, 2006 | 10:17 PM
Jerm93z28's Avatar
put in the stuff in your sig, and toss a set of dr's on it. there ya go.
Old Nov 15, 2006 | 08:01 AM
Sweetred95ta's Avatar
Sticky tires, a FAST 4k rpm clutch slip (if you want the 10 bolt to live), and a ton of practice. Good luck.
Old Nov 15, 2006 | 08:46 AM
Z-RATED94's Avatar
Actually, if you have decent power and want some good 60ft. times you might want to get a 9 inch. Sticky tires and high rpm launches (more than 4k)are brutal on rearends, but oh so much fun.
Old Nov 15, 2006 | 10:16 AM
2000GTP's Avatar
Sticky tires will be a must. But as mentioned above, you may want to consider saving up for a better rearend because the stock 10 bolt will only tolerate so much abuse.
Old Nov 15, 2006 | 10:57 AM
reamo04's Avatar
^like mentioned, im not sure if a 10 bolt will hold much past a 1.8, at least I wouldnt trust one past it
Check into bf goodrich g-force drag radials, or nito 555's, both work great.
Old Nov 15, 2006 | 01:25 PM
hulettsz28's Avatar
dr's, and a new rear end after a few good 60 footers.
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
