what will 4.56 do in my car from 3.42
Old Jan 29, 2005 | 06:42 PM
  #16
Kraest's Avatar
Retired
Re: what will 4.56 do in my car from 3.42
Originally Posted by Injuneer
4.56 gears with the deep 1st gear ratio of a 93 M6 seems unusual. Which tranny do you have the M28 (3.36 1st gear) or M29 (2.97)? What diameter tires are you running?
With an M28, you'd be running 15.32:1 overall in 1st gear. With his 2.66 1st gear, he'd have to run the equivalent of a "5.76" rear axle ratio to have the same overall ratio. Something sounds odd. Are you running 30+" slicks? And of course, all the gears in your 93 tranny are different than the later years, inclucing both O/D's so it wouldn't seem reasonable to directly compare results.
I agree.
It's a poor idea with 26" tires....I wouldn't even do it with 28" tires.
You'll be shifting into 2nd well before the end of the 60-foot.
At 6000 rpm you top out at 102 mph with 26" tires in 4th gear.
At 6000 rpm you top out at 110 mph with 28" tires in 4th gear.
Not a great idea.
Mike
Old Jan 29, 2005 | 08:05 PM
  #17
Mike94ZLT1's Avatar
Lol who cares what speed and rpm he will be running at. Stock 10 bolt + 4.56's + M6 + hard launch on street tires = BOOOM!!! no more mph at any rpm. Don't bother.
Old Jan 30, 2005 | 02:09 AM
  #18
GreenDemon's Avatar
Originally Posted by mattybz28
The tach may be off, but I think the speedo is off more than the tach is.
They're pretty close to the same. The problem is, 200 rpm off on the tach is a lot worse than 2 mph off on the speedo. I've seen radar on my car and it's almost dead on. The tach also swings alot quicker than the speedo, which doesn't help any either.
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
x7x7
Aug 15, 2002 06:49 PM
