What weight oil, 5w-30 or 10w-30?
Old Mar 29, 2006 | 10:42 PM
Camarocracy's Avatar
What weight oil should I put in my motor for the spring/summer? I currently have 5w-30 in it.
Old Mar 29, 2006 | 11:20 PM
HardcoreRM125's Avatar
Re: What weight oil, 5w-30 or 10w-30?
A 30 weight oil is almost too thin for an LT1. Alot of people have suggested runnin a 10W40. However, going with a 30 weight difference, the oil begins to loose its lubricating properties. 20W40 MAY be a nice summer oil. MAY ...
I just use Mobil 5W30. And it has always looked like brand new when I pulled the valve covers off and such.
Old Mar 29, 2006 | 11:23 PM
StephenDeli22's Avatar
Do you get more oil pressure with 20W40?
Old Mar 29, 2006 | 11:31 PM
JonZ28SS's Avatar
I'm all for Royal Purple 10w30. RP 20w50 would be even better if you wanna let it warm up every morning..
So far so good I've been using it for a while and it's been clean and I did notice a small oil pressure increase 5-10psi when I switched. Whatever you do, make sure its synthetic.
Old Mar 29, 2006 | 11:36 PM
TransAm396's Avatar
i do 10w40 in the winter and 15w50 in the summer
Old Mar 30, 2006 | 12:17 AM
Dansean1's Avatar
For winter go with 10-30 since its colder, hotter months I go with 20w50, cause here in Souther Cali, it gets damn hot!!! If mileage is high above 75k, generally go with a thicker oil.
One summer, I ran 10 30 and oil press was just above red when idling, oil thinned out to much.
Warming up the car is good to but I think let it warm up for 2-3 min, then drive it slowly til car warms up, cause oil only starts to lubricate and do its thing when its warm.
Old Mar 30, 2006 | 06:57 AM
FastLt1's Avatar
I have 80K and going to start spraying this summer. What weight Mobile 1?
Old Mar 30, 2006 | 07:32 AM
always faster's Avatar
From what i ve heard from the analize of lt1 oil, the best 2 choices are:
Castol German synthetic :0w30
or
Mobil 1 synthetic :0w40
Javier97Z28's Avatar
Moderator
I've run 10W30 Mobil 1 here in Florida the car's entire life with all my different setups (bolt-ons, cam only, heads/cam). Never had an issue with oil pressure.
Old Mar 30, 2006 | 07:41 AM
GreenZLT1's Avatar
I run 10w-40....
Old Mar 30, 2006 | 08:09 AM
Szizzle's Avatar
[QUOTE=Dansean1]For winter go with 10-30 since its colder, hotter months I go with 20w50, cause here in Souther Cali, it gets damn hot!!!
When you have spent 15 summmers in 110-120+ degrees anything at or below a 100 feels like a very nice cool day
I run 10w30 mobile1 synthetic. I would like it to run cooler in the summer but the car never gets too hot. I am going to put a 160* thermostat and a fan controller on the car to help keep it cooler.
"Gotta love the desert...the sun destroys everything...eventually"
Old Mar 30, 2006 | 08:31 AM
nfa's Avatar
nfa
There are a few local fbody guys that run oil analysis frequently (i.e. after every oil change), and they report very good results with german castrol 0w30. This is what I am using.
Old Mar 30, 2006 | 08:33 AM
Grn4fbody's Avatar
Ive put 10-40 in every Small Block Chevy ive owned. ONe even has over 200K still runs fine
Old Mar 30, 2006 | 11:52 AM
93turbo5oh's Avatar
i run 10w40 redline in mine all year round. has the best oil pressure of anything ive ever tried.
Old Mar 30, 2006 | 05:33 PM
96capricemgr's Avatar
http://theoildrop.server101.com/cgi/ultimatebb.cgi
I am tired of trying to dispell all the myths and missinformation on oil, that link is a wonderful one for those who choose to actually learn something about oil rather than keep on spreading missinformation.
