What is this tube/hose
Old Mar 22, 2007 | 08:42 PM
mycarisfasterthanyours's Avatar
My car has a small plastic tube that runs inside of the wire loom that runs from near the PCM towards the front of the car, down behind the battery and I believe from there it goes over to the driver's side of the car. The reason I ask is because it is broken near the battery. I have no idea how long it has been like that. Is there some sort of "schematic" somewhere that shows the hose/tube routing? I assume it has to do with emissions..maybe evap canister or something?
Old Mar 22, 2007 | 08:52 PM
SS RRR's Avatar
I believe it is your gas vent tube into the canister.
www.shbox.com
Old Mar 22, 2007 | 09:52 PM
It is the HVAC vacuum line from the check valve by the a/c pipes to the vacuum tank that is under the battery. It does not go to the driver's side of the car.
texasTA
Jul 4, 2005 12:14 PM
newbielt1
Oct 12, 2003 07:18 PM
