what transmission oil do you guys use in M6?
Old Apr 8, 2003 | 04:38 AM
alex-z28's Avatar
also how do you fill it up, I heard that you have to use a pump and a hose because its so hard to get in there.
Old Apr 8, 2003 | 05:36 AM
Hyperspeed97z28's Avatar
Try doin a search, you'll find more then the info your looking for....
Old Apr 8, 2003 | 01:13 PM
Laymaster's Avatar
I just changed to Honda ATF from the Honda Dealership. It works pretty well, and the shifting feels a little smoother now.
Old Apr 8, 2003 | 05:25 PM
Beast96Z's Avatar
Originally posted by aggiez28
syncromesh (sp)
brook
I've heard this is not a good fluid for the T-56, because it is to thick. Just hearsay though. The Honda ATF is good because it has a heat reducing additive for tight spaces.(Like in Hondas) Maybe the ol Mobil one synthetic would be good also.
Old Apr 8, 2003 | 05:31 PM
KillerTA's Avatar
I don't have it, but Horsepower TV gained something like 3-5 hp by replacing diff, trans, and oil with Royal Purple. I'm getting that stuff when I do mine.
Old Apr 8, 2003 | 08:41 PM
97FormulaWS-6's Avatar
I've got Mobil 1 Synthetic ATF in mine....
Old Apr 8, 2003 | 08:57 PM
BriansZ's Avatar
How long have you been running that in your tranny? Just wondering if you're having any problems, I've always been a Mobil 1 fan.
Old Apr 8, 2003 | 09:07 PM
Black94mula's Avatar
Definetly Mobil 1 synthetic ATF.....the best.
Well.... probably 2 years now... I've changed it once due to a clutch change....
Old Apr 8, 2003 | 09:10 PM
94ZGRNMCHN's Avatar
Mobil 1 syn ATF,works for me!
Old Apr 8, 2003 | 09:29 PM
Grease's Avatar
With over 500 passes down the 1/4 mile with my car powershifting, my transmission shifts as smooth as silk. I use Mercedes-Benz synthetic ATF, not because its the best but because I can get it for free from work. I think so long as you use an ATF the equivalent of Dexron III which is what is recommended by GM, you should be okay.
Old Apr 8, 2003 | 09:49 PM
94SLUG's Avatar
Originally posted by robvas
You can pour the fluid in from inside the car, if you remove your shifter.
How do you know when to stop? Why not just use the drain/fill plug?
Why not use gear oil?
Old Apr 8, 2003 | 10:10 PM
95 Z/28 LT1's Avatar
Super Moderator
You just put in 4 quarts. If you use the fill plug it's a PITA unless you have a setup like your local jiffy lube does.
When I had my tranny rebuilt by D&D Performance I asked them what to run and they told me the cheapest stuff I could find. I went with synthetic, and then when I pulled the tranny and replaced it with the Autozone cheap sh*t. Believe it or not the cheap sh*t is considerably smoother shifting FWIW.
Old Apr 9, 2003 | 01:44 AM
Laymaster's Avatar
I pour mine in from teh top. I pour in three full bottles and about 80% in of the last bottle, since it requires 3.8 quarts. If you're real **** about it, you can open the fill plug and let the excess drip out of there. I know that too much fluid is bad, but I figure that much human error is certainly negligable.
Old Apr 9, 2003 | 02:18 AM
limige's Avatar
i think i put 5 quarts in mine through the plug.
i just used some cheap stuff, used a electric fuel pump i had to pump it into the trans. worked pretty decent.
