What timing chain?
Old Oct 20, 2006 | 02:37 PM
69gto96z's Avatar
What timing chain?
I am getting ready to do a cam swap on my 96 LT1, and I don't know what kind of timing chain to use. The only one I have seen is the GMPP one for $250, I was wondering if there is another company that makes one for cheaper with the same if not better quality. Any help would be appreciated. Thanks
Old Oct 20, 2006 | 02:39 PM
Javier97Z28's Avatar
Moderator
Re: What timing chain?
If you are using an electric water pump, use the Cloyes 9-3145 double roller. Little clearancing needed on the timing cover, no big deal, and it's $79
Old Oct 20, 2006 | 03:06 PM
2000GTP's Avatar
You could always try to give Jason or Dal a call, they may be able to get it for you a little cheaper. I lucked out, I just snagged a whole LT4 timing set last week for 50 bucks with very little miles on it.
Old Oct 20, 2006 | 03:46 PM
MeanGreen97Z's Avatar
Which cam are you using? I am just going to use a new stock set.
Old Oct 20, 2006 | 07:26 PM
Daniel6718's Avatar
electric pump and the cloyes double roller!!! no exceptions...(unlike me)
Old Oct 20, 2006 | 07:30 PM
69gto96z's Avatar
I wasnt gonna do an electric waterpump, but it would come out cheaper to do an electric w/p and a double roller.
Old Oct 20, 2006 | 07:33 PM
ulakovic22's Avatar
I say elec. w/p and true double roller. If not just get a new chain from Thunder Racing and use the stock sprockets. You could also get the oversized sprocket while your at it to help with the timing chain slack.
Old Oct 20, 2006 | 07:37 PM
huskersZ's Avatar
u will more than likely come about maybe just a little cheaper with an electric and true double roller. CSI/CSR pumps used to be carried by summit 4 130ish+ 79.00 4 the timing chain= 210 total
Old Oct 20, 2006 | 07:43 PM
69gto96z's Avatar
I will probably do that. Thanks for the info.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
