what thread sealer do you use on studs
Old Oct 6, 2007 | 01:56 PM
Blownbird355's Avatar
I have used the ARP teflon stuff I have some GM pipe sealant but it cures. What is the part number for the permatex or gm non curing thead sealant?
Old Oct 6, 2007 | 02:38 PM
Stl94LT1's Avatar
I used the GM pipe thread sealant, didn't cure on my threads.
Old Oct 6, 2007 | 04:05 PM
MachinistOne's Avatar
GOOGLE IT!
http://www.permatex.com/products/ind..._2_Sealant.htm
Old Oct 6, 2007 | 04:52 PM
speed_demon24's Avatar
ARP thread sealant, and it was leaking...
Old Oct 6, 2007 | 06:17 PM
wrd1972's Avatar
ARP here, no leaks.
Old Oct 7, 2007 | 10:39 AM
MachinistOne I was on their site but was in automotive not industrial.
Also do you like the stuff?
Old Oct 7, 2007 | 01:15 PM
Permatex # 2 is the best thread sealant IMO, and I've never had leaks with it...make sure the threads are clean and dry before installation.
Old Oct 10, 2007 | 01:38 AM
1982z28with18s's Avatar
I agree, #2 is VERY good
Old Apr 9, 2008 | 07:02 PM
c0rey's Avatar
Ive got to do mine over again on the heads. Whats the best way to make sure they are screwing into a dry hole? What steps do you take before putting in the bolt?
Old Apr 10, 2008 | 01:03 PM
DAVE00's Avatar
Good blast of air from a compressor or air can. Have a towel handy as it can get messy!!!
Old Apr 10, 2008 | 05:06 PM
Josh'95Z28conv's Avatar
Dude, Permatex #2 is NOT a thread sealant. Its form a gasket. I used it and the next thing I knew coolant was in my oil! Upon disassembly I found none of the threads had any of that crap left on it, it was all washed away! All that was left was rust in my threads
Read the instructions for what you are using. I used this:
http://www.permatex.com/products/Aut...ad_Sealant.htm
Suggested Applications: Head bolts into through holes
Permatex #2:
Suggested Applications: Valve cover gaskets, oil pan gaskets
I know arp had a bad batch of thread sealant. Personally Id go back with them or use the permatex thread sealant I recommended. Dont use permatex #2.
Old Apr 11, 2008 | 05:07 AM
My friend used ARP just about two months ago even though I told him not to and to just use #2...yep his leaked coolant.
I've used #2 for 4 yrs now without a problem, and know many others who have used it without any problems either, it DOES WORK if used properly.
Old Apr 15, 2008 | 06:34 PM
Yea, because you used it properly and I didnt
Its not thread sealant. It was NOT designed to seal threads. It DID NOT work for me.
FYI, I work on/ build engines for a living. I know what Im doing. Ive done countless number of head gasket swaps, and the only time Ive ever had a leak was with permatex #2.
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 22, 2015 02:31 PM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
